Old 08-Feb-2005, 23:48   #1
keefer keefer is offline
keefer's Avatar
outer clutch basket movement ?
right striped down the clutch today ready to be cleaned. and after I had undone the centre nut and removed all the bits I was just left with the 8 retaining bolts for the outer basket.
ok whipped them off with the windy gun then went to remove the basket.
now when I pulled it there was some sideways play in the hub about 5mm at a guess ? is it meant to be like this or do I need to take off the crank case cover and investigate further ?
Old 09-Feb-2005, 13:29   #2
DSC Member Karl Karl is offline
Karl's Avatar
Was there any oil on the seal behind the basket?
Old 09-Feb-2005, 13:35   #3
keefer's Avatar
no its a relatively new seal. I just don't remember the hub moving this much before ?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:05.
