General Motorcycles only
Old 09-Feb-2005, 19:50   #1
ali ali is offline
ali's Avatar
Mood: Damp
Cast Iron discs?
Hi,
Just received a couple of cast iron discs bought from fleabay:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...tem=7950902787
Having got hold of them there's two questions:
1) Why don't they rust when I run water over them like mine do on my SL?
2) Did brembo ever make cast iron discs with steel carriers, because these definitely aren't alloy?
The discs are in really good nick, with virtually no wear, although they are a little on the blue side. I'm aware that brembo also did a high-carbon iron disc but, again, I thought it came on an alloy carrier.
Help, I'm confused!!
Cheers,
Ali
Old 09-Feb-2005, 20:05   #2
keefer keefer is offline
keefer's Avatar
don't want to be the bearer of bad news but they don't look like cast iron discs to me.
look like standard alloy with those carriers
Old 09-Feb-2005, 20:09   #3
ali ali is offline
ali's Avatar
Mood: Damp
That's what I was thinking.....
Weight is 1950g per disc/carrier.
Old 09-Feb-2005, 20:12   #4
adam adam is offline
Mood: happy
mine rust as soon as it gets cloudy
Old 09-Feb-2005, 20:14   #5
bolds bolds is offline
sorry Keefer is correct they are standard discs as fitted to 916/748 SS and Monsters etc with steel carriers
Old 09-Feb-2005, 20:19   #6
P.S £107 each plus vat for New ones
Old 09-Feb-2005, 21:04   #7
Mood: happy
I think a message to ebay and the seller of the discs.
Old 11-Feb-2005, 10:52   #8
Nattyboy Nattyboy is offline
Nattyboy's Avatar
Mood: Back down to 3 :>(
Yep Ali..im with the other guys...the discs themselves also have the standard drill pattern (see attached for comparison).
The only other version of a cast iron brembo disc ive seen is the hard anodised race version which has a greeny coloured carrier.
Im sure youll get it sorted mate..good luck
Nat
Old 11-Feb-2005, 11:36   #9
ali ali is offline
ali's Avatar
Mood: Damp
The guy has accepted full responsibility, grovelled, and is refunding the full price plus postage. Seems a genuine mistake so no harm done.
Natty: Snap:
What pads are you using with the cast irons? I could only get hold of sinterteds suitable for stainless, but at £45 pair I'm not sure I can afford to change!
Old 11-Feb-2005, 18:14   #10
yeti yeti is offline
yeti's Avatar
Gorra set of genuine cast iron discs if you are still interested.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:48.
