Old 09-Feb-2005, 20:35   #1
suspension upgrade question
Before I put the T8 back together do I upgrade the suspension as the forks will be out for the head bearing change.
I wont be using it for track days only road use I dont have any real issues with the showas except there a little on the hard side and not very adjustable.
has anyone changed to something other than ohlins with a visible benefit.
I will change the back setup as well if its worth it.
ian
Old 09-Feb-2005, 21:19   #2
yeti yeti is offline
yeti's Avatar
Fit softer springs in the forks and maybe even a softer one in the rear. Folks like K Tech can do the job while you wait if you book in with them. Sadly I can no longer recommend KAIS.
Old 09-Feb-2005, 21:32   #3
chicken chicken is offline
chicken's Avatar
One upgrade option would be switching to Ohlin internals.
Alternatively, you could switch to sbk forks although many on the board would consider this sacrilege. If you do want to go down this route, speak to Nelly - he has already done this on mine so the real-world "R&D" has already been done.
Old 09-Feb-2005, 23:15   #4
paynep's Avatar
Mood: Wet wet wet
FWIW, I use my 888 for road track and race and standard forks are fine. I changed to 7.5w oil (mix 1 bottle of 5 and 1 of 10w and use half the total!) and got Baines to set the rear up for my weight (13st in leathers)
Old 09-Feb-2005, 23:19   #5
13 stone in leathers!!!
Someone buy this man a steak!
Old 10-Feb-2005, 21:10   #6
paynep's Avatar
Mood: Wet wet wet
Cutting out the pies is always cheaper than buying carbon to save the odd kg!!
Old 11-Feb-2005, 00:45   #7
sparkin sparkin is offline
sparkin's Avatar
Yep I have,or am.Just fitted the hyperpro combi kit to mine(well I haven`t,Carl Harrison motorcycles have)hoping to get the bike back for March.I have used the kits before on a SS and really liked it
Recommended.
Old 11-Feb-2005, 12:31   #8
But I lurve pies ...
I'm going to have to fit some ballast to your DD bike somewhere ...
Old 18-Feb-2005, 21:00   #9
sparkin's Avatar
Just thought I`d post a pic(not very good thou,camera phone)of my new rising rate rear spring I know it should be purple,but I couldn`t have that
