Old 11-Feb-2005, 00:06   #1
sue reade sue reade is offline
Ducati 999 - misfire /horizontal cylinder
Hi
I hope someone out there can help me, i bought a Ducati 999 in December 2002, and it has recently developed a misfire horizontal cylinder when cold. Hope you can HELP ME
Old 11-Feb-2005, 00:13   #2
nathanhu nathanhu is offline
nathanhu's Avatar
Mood: head down
take the plug cap off the front cylinder and clean the socket with a little WD40and look inside the receptical for the plug for green oxidization on the pins .
check that the oil cooler fairing hasnt chafed the cable were it runs over the edge of the cylinder head ,
lastly check the plug if the abouve fails
Old 11-Feb-2005, 00:14   #3
nathanhu's Avatar
Mood: head down
have you just washed the bike or ridden in the rain
Old 11-Feb-2005, 00:18   #4
madmav madmav is offline
Bikes: 1098
madmav's Avatar
Mood: Chilled
sue does it clear up when hot?
does it stop misfiring
Old 11-Feb-2005, 00:18   #5
nathanhu's Avatar
Mood: head down
on my old 2003 bike i got my dealer to replace both spark plug caps/coils under garantee for the new type fitted to the last 2004 bikes and the 2005 models , easly recognisable by the long lead coming from the plug cap , i had no end of problems with front cylinder misfire
Old 11-Feb-2005, 00:26   #6
Hi
Thanks for the advise, i have had coils changed, and am going to try draining the fuel tank as prone to water ingress, the problem only shows up when the weather is cold. I will keep you updated. Thanks again
Old 11-Feb-2005, 10:46   #7
Hi
Drained fuel tank - no water, not sure what to try next, can anyone else help.
Old 11-Feb-2005, 10:53   #8
If it was a fuel problem as you are suggesting water, it would misfire on both cylinders! You are saying the front cyl is misfiring right?
Is it a constant misfire of now and then?
If so when does it do it?
You need to inspect all the electrical high tension stuff first like plug, cap lead etc.
Old 11-Feb-2005, 16:48   #9
neil748r neil748r is offline
This sounds just like the problem encountered by quite a few guys that race the 999. It's also a known issue to Ducati UK. The cure is to replace the stock "all in one" plug cap/coils with the appropriate replacement parts from the 749R.
Hope that helps, Neil.
Old 11-Feb-2005, 20:20   #10
Thanks for advice Neil all the coils have been replaced with 749R, i have also transposed them, and the misfire is still on the No1 cylinder in the cold weather on initial start. I have tried lots and lots of other things and still faulty.
I'm Colin my wife is Sue, we have only just gone on the internet, still trying to find our way around, not set up my e.mail address yet so all replies to Sue Reade please.
I'm working till 9pm tonight, but when i come home, perhaps i can e.mail you to swop info.
Colin
