Old 13-Feb-2005, 18:13   #1
Tokico brakes spares contacts anyone?
Not quite Duke stuff I know but I've ended up going inside the 6-pot calipers I've bought as one of the pistons was stuck.
Does anyone know of a supplier that does seal kits / pistons etc?
Regards - Frank
Old 13-Feb-2005, 18:33   #2
Dunno really, but the Tokicos are standard fitment on the ZX10R and GSXR (I think), so I'd imagine that spares should be available somewhere. I know the exact calipers are different, but components may be interchangeable?
Tim
Old 13-Feb-2005, 18:41   #3
Yep - TL1000's & ZX6R's also have them as well I believe.
Just trying to source a supplier as I'm not overkeen on re-using the body or piston seals.
Its an excuse for buying this weeks MCN and winning TWO bikes I suppose
Frank
Old 13-Feb-2005, 19:24   #4
Ian900SLV Ian900SLV is offline
Mood: All SP'ed up at the moment
Try here Frank
www.123bikes.co.uk
seem to have a good range
Ian
[Edited on 13-2-2005 by Ian900SLV]
Old 14-Feb-2005, 11:18   #5
Cheers Ian - good range of items but a bit expensive for what appear to be 'pattern parts'.
Having said that I can't find ANY contacts for Tokico in the UK via the 'net or MCN yet....
I'm cleaning all the seals up VERY carefully at the moment !!!
Thanks - Frank
Old 14-Feb-2005, 20:05   #6
If it is just the seals you want, then look up your local bearing/seal supplier in the yellow pages, take a sample to them and they will match them up for ya and save you a fortune.
Ian
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:48.
