Old 17-Feb-2005, 00:05   #1
Alternative sprag clutch design / manufacturer
Blimey...I'm on a roll tonight.
I might eben ask about prices as I'm sure this is the main fault aflicting my bike at the moment:
http://www.ducatimeccanica.com/Howdi/
Frank
Old 17-Feb-2005, 00:08   #2
SORRY...forget that...its only for BEVEL drive Ducati's at the moment !!!
Old 17-Feb-2005, 00:53   #3
phil_h phil_h is offline
phil_h's Avatar
That looks a nice piece of kit, and spookily similar to the belter one too !
I'll have to bring my 2 broken ones in and compare them to the photo
What's your prob just now ?
(post thread link rather than repeat it all if its on here somewhere)
Old 17-Feb-2005, 01:34   #4
Too much to tell Phil !!!!
last problem.....
http://217.199.188.40/xmb/viewthread.php?tid=13797
Sprag problem.....
Motor struggles badly to turn over even on a warm day. So much so that even an uprated (and with an emergency starter battery) also struggle to fire the beast up at times.
Its fine once the engine is hot - but from cold, most times forget it!
Some work to do I suspect.
CHeers - Frank
Old 17-Feb-2005, 11:05   #5
Derek Derek is offline
Bikes: ST4s ABS
Derek's Avatar
Frank,
Your problem is not the sprag clutch. When the clutch fails the starter turn OK but doesn't turn the motor. i.e. The clutch slips.
I think you should be looking at connections from the battery to the solenoid and from the solenoid to the starter. Particulary the terminal on the starter which collects a load of road muck under the rubber boot and is susceptible to corrosion. Check also the earth cable from the battery -ve to the frame connection and don't forget to check the terminals of the frame to engine earth cable which is beside the crankcase breather, hiding behind the RH footrest hanger.
If all these connections are clean and making a good contact with no improvement, try bridging the solenoid terminals with a large screw driver. If the motor turns over quicker then the solenoid is faulty. Possibly burnt contacts inside it.
If none of the above gives any improvement I think you should be looking at the starter motor itself, probably brushes. Which I believe can be replaced without removing the starter. (Haven't done it myself though)
Old 18-Feb-2005, 01:48   #6
Cheers - Derek.
Sadly all the components you mention (apart from the engine earth) have all been renewed in the last year and the starter motor rebuilt as well.
I'm thinking of handing over to a professional anyway
Once I've saved enough dosh !!!!
Frank
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:45.
