Old 05-Jul-2003, 18:18   #1
Viper Viper is offline
Mood: Desperately seeking sunshine!
Fitting exhausts....grrrr.....
Having had my 748 two weeks now, i thought the neighbours should be adequately aclimatised to the new Ducati noise levels by now, so i thought i would finally fit my little Termis on.
Now, the left has gone on no problemo....despite lots of cuts from the evil sharp edges of the brackets.
But the right is being a complete and utter bitch.
I cant seem to get enough upwards clearance to get it remotely near to slotting in. Meanwhilst, the carbonfibre is being 'nicely' ground away by the bottom on the mounting point bracket!
Grrrr!!
Help...work in progress... but i'm beginning to get very frustrated...
Does anyone have any tips or hints to help me! Preferably before i kick the damn bike over, and go out shopping for R6's.
Anything remotely useful will be much appreciated!
Vx
Old 05-Jul-2003, 18:33   #2
TopiToo TopiToo is offline
Bikes: 748ish . .
Mood: Sampai jumpa lagi
Hello Viper,
Not that I can be of much help, But I have spent the best part of the day trying to achieve the same thing.
Down pipes all on no problem, I took off the rear pegs to give me more room, and funny enough I found it easier to get the right on, left still to do . .
I am sure there is a simple trick, and somebody out there must know . .
Good luck .
regards
TopiToo
Old 05-Jul-2003, 18:51   #3
Well its slightly reassuring to know that i'm not the only one battling. My fingers are crossed for you 'left'.
Hmmmm.... well my exhaust fits on if i hang it on at 90degrees to the side of the bike. I could start a new craze!
...or perhaps not...
Ok, i'll continue to struggle then. Doh!
Vx
Old 05-Jul-2003, 20:10   #4
Desmoboy Desmoboy is offline
Guys
What you need to do is take off the seat unit, undo the bottom subframe bolts and lift the subframe at little. This will give you enough space to swing the exhaust into place.
Old 05-Jul-2003, 20:20   #5
Viper - if it helps.......
......I'm around the Reading area tomorrow afternoon - 5ish and can pop over to offer some assistance if you like?
Drop me a U2U or email to arrange if it suits...
Tim
Old 05-Jul-2003, 20:27   #6
Harv748 Harv748 is offline
Harv748's Avatar
Fitting exhausts
Ditto Desmoboy.
Just remove the two most rearward bolts of the subframe, and loosen the other two, allowing the subframe to pivot up by an inch or two.
I had EXACTLY the same thing when fitting mine.
Don't force it...move the subframe slightly first.
And another tip (I think this originally came from Tim!) when fitting the hangers on with the rubbers, and trying to position them in place, spray the rubber with WD40. It allows them to be moved around on the can, wihout them poping out of the bracket every time they are moved.
Old 05-Jul-2003, 20:58   #7
Cheers for the help guys!
I was about to consider the subframe bolts as 'next viable option', however...
After many many many many many many wiggles, and getting a variety of strange looks from the neighbours, i manged to finally get the little bugger to slowly slide into place.
Luckily I am not blessed much 'brute force' talents, otherwise i probably would have just bent it!
However, now they are finally on, they do actually appear to be fairly skew-wiff, to my perfectionist eye Its all a bit dodgy if you ask me.
However, they're on, so "yey" I shall complain no more!
Cheers for the offer of help Rattler.... I may save the 'offer' until 285 days time... When the bloomin' MOT will be due, and the bloomin' things will need to come off again!
Vx
[Edited on 5-7-2003 by Viper]
Old 05-Jul-2003, 21:34   #8
tont2002 tont2002 is offline
Mood: waiting til next summer ;)
ha ha.. i got all this yet to come, when i get mine.. best print off page... LOL
Old 05-Jul-2003, 22:11   #9
Hmmm.... I've been considering it.
Although that would involve actually getting out of bed at a relatively 'useful' time. Which is always a bit of a challenge.
Vx
Old 06-Jul-2003, 02:43   #10
Bikes: 748ish . .
Its not what u know its who will help. . .sorry I bothered . . no offence Viper . .
regards
TopiToo
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:38.
