Old 18-Feb-2005, 14:39   #1
Roy748Bip Roy748Bip is offline
Mood: skint.....
748 Timing Belts
I've just serviced my new toy ('95 748) and replaced the timing belts. I didn't fancy paying the £370 quoted from my Dealer for the tensioner meter so I used Nelly's 4mm Allan Key method.
I just have one concern and that is on the horizontal cylinder when tensioned correctly the belt between the adjuster pulley and the opposite pulley is approximately 2mm apart. I don’t remember it being that close when I started. Is this OK? Or have I done something wrong?
Any help would be appreciated.
Old 18-Feb-2005, 15:55   #2
DSC Member simonducati simonducati is offline
Bikes: Had 748,749, 848 and now a 1199 Panigale
simonducati's Avatar
Mood: Living the dream.
I’m getting mine done for £135 tomorrow.
You tied it your self but when your engine go’s your going to have to pay a bit more then you were quoted
Old 18-Feb-2005, 16:09   #3
Invest in a Snap-on or Facom tensioning tool, they are very similar to each other and a lot cheaper than the Ducati one.
Old 18-Feb-2005, 16:37   #4
Hmm, the only way that i can see something like that happening is if the belt was too long. There is no way you could over tension it so much without snaping the thing!
Also worth turning the engine over a few time and trying the tension again (by hand not on the button)
Old 18-Feb-2005, 19:29   #5
PeteB PeteB is offline
PeteB's Avatar
Mood: ten, nine, eight oh bu**er lets go!
Roy,
Is there a possibility that you turned the tensioning pulley the wrong way? ie you tensioned the belt by moving the pulley clockwise instead of A C/W ??
Old 18-Feb-2005, 20:18   #6
The allen key method, slipping it between the idler pulley is for 2V motors.
The 4V are a little more involved. You need to measure the belt deflection between the two cam pulleys. It should be 5mm.
Tenion the belts "tight", turn the motor over a couple of times and then line the timing marks up. Scibe or pencil a line on the cover behind the belt, between the pulleys. Use this as the datum to measure the 5mm deflection.
Tension the horizontal cylinder only.
The rotate the motor 3/4 turn anti clockwise to put the vertical cylinder at TDC. Then tension that belt.
Only add tension to the belts turning the tensioner anti clockwise.
Old 18-Feb-2005, 20:40   #7
m1keyp m1keyp is offline
Does anyone know the facom tensioner part number or description?
Old 18-Feb-2005, 21:56   #8
Mood: skint.....
Nelly / PeteB
Thanks for the info, I seem to have done everything OK, except applied a 4mm deflection between the cam pulleys rather than 5mm.
Maybe i'm just worrying about nothing! I think i'll try to get a tension meter in the near future though.
Old 19-Feb-2005, 01:08   #9
The info on the Facom tool part No. DM1.6
http://193.150.169.26/page/Ensemble_..._Ensemble=2607
http://193.150.169.26/Frame.asp?langue=an&Cat=427
[Edited on 19-2-2005 by skidlids]
Old 19-Feb-2005, 12:31   #10
moto748 moto748 is offline
I understand ( and I await elaboration from those who know better than me) that not all 748 engines are the same, and they can take different belt part numbers. My bike although nominally a 748E, does not, in fact, have a an "E" engine, but a Bip engine, which has different belts.
Not saying this is Roy's problem, of course. Just thought it was worth mentioning.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:48.
