Old 19-Feb-2005, 00:28   #1
geoff m geoff m is offline
geoff m's Avatar
Mood: So its raining, your problem with that is ??
CRASH BUNGS
Hi
What type is best for a 916, ?
Any suggestions folks ?
Ta
geoff M
Old 19-Feb-2005, 00:30   #2
Felix Felix is offline
Do a search as this has been well covered before. The short answer is you don't want them.
Old 19-Feb-2005, 09:37   #3
ducv2 ducv2 is offline
Well, I've just got a set of R&G bungs, which were flaming expensive and will not fit without worrk to the clamp plates. Reckon they will be OK on a low speed off but not so sure at higher speeds. Reckon I will have other things to worry about though. Going to fit them in an attempt to protect the clutch.
Old 19-Feb-2005, 11:32   #4
centurysup centurysup is offline
Crash bungs are fine for the track where there are no potholes, drain covers etc and the bike will slide cleanly.
Different story on the road. If they snag on something they can cause serious damage to the frame or whatever they're anchored to.
Old 19-Feb-2005, 11:46   #5
yeti yeti is offline
yeti's Avatar
Don't! As an engineer I have never been fully convinced they would protect rather than cause more damage.
That said I am looking at designing a set that mount onto an extended engine bolt but with large diametre mushrooms rather than the tubular type normally used.
Watch this space - tho I still remain sceptical.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:09.
