Old 06-Jul-2003, 09:56   #1
logyk logyk is offline
logyk's Avatar
Mood: Relaxed - don't worry about things you can't change
996S - Brakes
Keep getting a juddering from the brakes on first application from high soeed in particular.....which reduces as the brakes are pulled on more firmly.
Anyone got any ideas....my first fear was warped discs.
The bike is still under warranty.....should this be covered ?
Any sensible comments would be much appreciated.
Old 08-Jul-2003, 08:31   #2
Mark853 Mark853 is offline
Mood: The medication helps!
996s brake judder
Sounds like disks to me, mine were doing the same thing so i got them sorted under warranty no problem.:sing.
Old 08-Jul-2003, 09:19   #3
Defo a warantee job.....
......if it is warped disks, it ought to show up more so on heavy braking!!
Have you checked the pads?
Tim
Old 09-Jul-2003, 10:34   #4
Mood: Pensive
SEP
I my experience of warped discs, when moving the bike around at slow speeds (e.g. in the garage), the lever will need "pumping" to get the pistons back from the point at which the warped discs have pushed to them out to.
Then again, you could just take a blase walk into your dealer and register it in your mind as an SEP (someone else's problem).
Old 09-Jul-2003, 19:50   #5
logyk's Avatar
I have decided that SEP is the best route.
The bike will be going back to the dealers for some TLC under warranty.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:00.
