Old 23-Feb-2005, 12:31   #1
Wylie1 Wylie1 is offline
Wylie1's Avatar
749s gearing
I've got a 2003 749s & I want to lower the gearing. I usually get a 1 tooth smaller front sprocket, but it seems I can't do that as the standard one only has 14 teeth.
My only option it seems is to go bigger on the back. Has anybody done it already? Can I go 2 teeth bigger with the standard chain?
PS. I know I need a suitable avatar - it's on the way!!
Old 23-Feb-2005, 12:41   #2
Twinfan Twinfan is offline
Twinfan's Avatar
You'll need a new chain. I thought about doing this too, but never got round to it. See this thread for details:
http://217.199.188.40/xmb/viewthread...6156#pid142860
Old 23-Feb-2005, 13:04   #3
Wylie1's Avatar
Thanks for the link - very useful.
I've ordered a rear with 2 extra teeth. If it doesn't fit with standard chain, I'll just order one with 1 extra tooth. I'm not concerned about shortening the wheelbase as it isn't the quickest steering bike!
I'll let you know if it fits.
Old 23-Feb-2005, 14:56   #4
cj2 cj2 is offline
Bikes: Multistrada 1200s DAir
I've just fitted a 1 tooth larger rear sprocket (39T) to my '04 749s - std chain was o.k. but I doubt I could have got another tooth without longer chain. I'm not sure if this helps 'cos I think the '03 749s may already have a 39T whereas '04 has 38T
I haven't ridden it yet by the way.
Old 23-Feb-2005, 14:59   #5
khu996 khu996 is offline
khu996's Avatar
I don't think you can go two up on the rear without buying a longer chain, I've had it done, and you need a couple more links!
It does make a fantastic change though, the bike feels much more responsive
Old 23-Feb-2005, 15:53   #6
revdecal revdecal is offline
Mood: Busy, Busy...Busy!
To gain the same effect as 1 down at the front and 2 at the rear, I have gone 3 up at the rear.
Has the same effect with lots more drive...but i did need to get a new chain. Needed one anyway so it all worked out!!
Old 23-Feb-2005, 21:54   #7
tricky tricky is offline
Mood: Need spares
Has anyone got rough costs of a new rear sprocket and chain ?
I fancy going up 3 on the rear.
Cheers, tricky
Old 24-Feb-2005, 01:29   #8
cost me about £120 at the ally pally.renthal sprocket and gold x ring DID chain
Old 24-Feb-2005, 12:44   #9
Reaper Reaper is offline
Chain length
Revdecal,
What length chain did you need (to retain standard wheelbase) when going up three teeth on the rear?
A 98 link? (up two from standard)?
Thinking of going 15/39 myself when chain needs replacing. I've run 14/36 for the last 6,000 miles and the chain is now showing signs of stretch.
R.
Old 24-Feb-2005, 13:12   #10
Mood: going for a ride...
1 down at the front and 2 up at the rear would be more like 4 / 5 up at the rear
