Old 27-Feb-2005, 21:53   #1
aka.eric aka.eric is offline
oil leak
Annoying leak around oil filter.Doesnt leak when engines running but leave for a hour or so and drips down the side of the filter onto the exhaust.Anyadvice?
Old 27-Feb-2005, 22:00   #2
ericthered40's Avatar
Mood: renegade sexy racer
Is the oil coming from the filter seal or from the engine casings and ending up round the filter ?
Old 27-Feb-2005, 22:13   #3
Mr_S Mr_S is offline
If you can't easily spot the source of the leak, try dusting the casings with a bit of talc.
This absorbs the oil, preventing it from running all over, and should make it that bit easier to spot the leak
Old 27-Feb-2005, 23:32   #4
Could also be cutch fluid or in my case it turned out to be chain lube!
Old 27-Feb-2005, 23:39   #5
I can only see the oil coming down the side of the filter,usually push a piece of kitchen towel up into the filter recess to wipe it.Got me worried now,do he casing leak
Old 27-Feb-2005, 23:52   #6
Don’t get to worried yet It’s just that being right at the bottom anything can end up there.
If the oil is coming from the filter seal and the filter is not loose,
Try draining the oil out, clean and check the filter seal and the seat were it seals to the engine
If all looks ok then re fit the filter you have with just a light film of oil on the seal.
Could just be some c**p on the seal from when it was fitted or a dodgy filter seal
hope this helps
Old 28-Feb-2005, 00:59   #7
Festa748 Festa748 is offline
Festa748's Avatar
If the bike has been stood a while when you have started it up the oil filter will leak as the seal around the filter will have gone dry.
Best thing is do an oil and filter change and check it when you put the filter on. and oil the seal on the new filter with old engine oil then do the filter up hand tight only. Should be ok after that but do a good cheak when the filter is out but i cant see it being a big thing
