Old 28-Feb-2005, 22:19   #1
paynep's Avatar
Mood: Wet wet wet
ST4S marchenisis ?
Anyone know if the 5-spoke marchenisi's are lighter than the standard 3spoke brembos ? If so, by how much and is the rear 5.5 or 6 inch wide?
Cheers, Paul
Old 28-Feb-2005, 22:28   #2
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
Yes they are although I can't remember by how much and the rear on the 4S is 5.5" wide.
Old 28-Feb-2005, 22:34   #3
Rushjob's Avatar
Mood: :-)
Found this courtesy of one of Shazzam's posts....
Rear
Marchesini 5-spoke aluminum - 12.0 lbs
Brembo 3-spoke aluminum - 13.3 lbs
Front
Marchesini 5-spoke aluminum - 9.2 lbs
Brembo 3-spoke aluminum - 11.5 lbs
Old 28-Feb-2005, 23:50   #4
paynep's Avatar
Mood: Wet wet wet
Thanks Rushjob,
The std 3-spoke weights are as per the Dymag website for a 916 so the front is probably the same, but the rear will be heavier as it has bearings/cush drive etc that the 916 doesn't........
So they still look to be about 4lb heavier than mag wheels......
Old 28-Feb-2005, 23:55   #5
Henners Henners is offline
Damn sight easier to clean the three spokes - I prefer 'em
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:03.
