Old 01-Mar-2005, 14:27   #1
Mood: aving a laff
Gearing for Cadwell?
Got Cadwell next weekend and was thinking about the gearing for that track.
First time out on the 748 so not really up on what it needs to be running.
Got 14/40 on at the moment and I have a selection of sprockets to go with so it will be easy enough to alter on the day but just wondered what other people ran there?
Bikes has a 748 SP engine if that helps?
I have the spreadsheet for the gearing but wondered if peeps have a preference?
Old 01-Mar-2005, 19:00   #2
Felix Felix is offline
I run 15/50 but that's with a slightly different engine to yours. At a guess, you'll get to 160 MPH down park straight on the 748SP as long as get Charlies 2 right. Use that speed and suit gearing to hit a couple hunderd RPM below the redline. Also turn up the idle to about 2500 RPM. No reason why you can't hit 1:45ish with that.
Old 02-Mar-2005, 12:03   #3
Mood: aving a laff
Cheers Felix, will sort the spreadsheet tonight.
Slightly different engine just a lot
15-50 Jeez thats big.
You running a Corse swingarm as well?
Your chain must be 118 links long?
See you at Croft in April?
Old 02-Mar-2005, 12:19   #4
Oops, make that 15-40.
Old 02-Mar-2005, 14:27   #5
Ray Ray is offline
Ray's Avatar
Cadwell, is currently under 4-6 inches of snow.
gearing might be the least of your problems!!
A car rally got cancelled there last weekend, I'm supposed to be there this Friday on a car day.
Ray.
It should be clear by the 12th, if not I reckon gear it for 16mph on the straight!!
Old 02-Mar-2005, 14:33   #6
Mood: aving a laff
Motox knobblies instead of wets then?
Felix,
Thought you might have been taking the mick a bit?
Will have to see on the weather front eh?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:13.
