Old 02-Mar-2005, 23:25   #1
RickyX RickyX is offline
RickyX's Avatar
P34 Caliper Brake Lines
Just bought a pair of individual brake lines to fit to the P34 (4 pad) calipers that I bought from Adam (cheers mate, got your letter).
Since I am fitting these calipers to a 916SPS, I had to order the hoses to fit the SPS master cylinder with a double length banjo bolt and with end fittings suitable for the P34 calipers.
When ordering them, I said that they should be made to fit a 996R or 748R as these have those calipers as standard.
Just managed to venture into my garage to trial fit them and noticed the following:
- the caliper end banjo fittings are angled at 60deg so when the hose is attached to the caliper it sticks out at 60 degrees (upwards/outboard from bike centreline)..this doesn't seem right!
For the hose to go around the back of the fork leg, I would expect the banjo fitting to be straight or maybe angled at 10degrees or so to clear the mudguard - have any "R" owners got advice on this?
- with the fittings at 60 degrees, I then thought maybe these are hoses that are designed to go around the front of the fork legs (like on a race bike) - have any "R" owners got these type of hoses and if so, are the banjo fittings at 60degrees?
Comments/advice would be much appreciated from the elitist and privileged few who own "R" type bikes fitted with 4 pad calipers...
Cheers,
R X
p.s. it's not snowing now.
Old 02-Mar-2005, 23:36   #2
neil748r neil748r is offline
Sounds like they've sent you lines to fit a 749R or 999R with radial 4 pad calipers.
Old 03-Mar-2005, 09:16   #3
RickyX's Avatar
I dunno...it says "996R" on the packaging.
Old 03-Mar-2005, 10:52   #4
OK, so what are the banjos like on the other end of the lines? Quite often, they are at a slightly unexpected angle, this is to ensure that they don't interfere with each other.
Is it possible you have them the wrong way round?
Old 03-Mar-2005, 15:31   #5
RickyX's Avatar
Nah..not the wrong way round, I tried both ways!
Anyway, spoke to the shop and they will re-make them - I think they sent hoses suitable for the original 996 65mm spacing calipers as they have a 60-90degree bend on them.
Ta for your interest.
R X
[Edited on 4-3-2005 by RickyX]
Old 03-Mar-2005, 18:14   #6
Jasper Jasper is offline
Jasper's Avatar
This is what they should look like.
Old 03-Mar-2005, 22:22   #7
adam adam is offline
Mood: happy
Richard, you could have had my hoses
Old 04-Mar-2005, 13:37   #8
RickyX's Avatar
Cheers mate, I have sent that piccy with the returned hoses so that they can make them correctly.
R X
Old 04-Mar-2005, 13:44   #9
RickyX's Avatar
Oh cheers Adam, I didn't know you had any!!!
Maybe if you'd remembered to put them in the box with the calipers I would have avoided this extra hassle!!!!!
Never mind, as Phil Oakey "sang":
"I’m only human
Of flesh and blood I’m made
Human
Born to make mistakes....."
What a cr@p song..but kinda catchy in a poppy sort of way.
R X
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:31.
