Old 03-Mar-2005, 14:50   #1
Fax modems
Now when i was on good old dial up i could also use my modem to send faxes. Am i right in thinking that now i'm on broadband i can no longer send faxes?
Sorry, i'm not at home at the moment so i cant try it out. Its just that i have re inherited my old PC which had a modem with it so if i can use it for something i might keep it.
Old 03-Mar-2005, 14:53   #2
You know I have asked myself the same question, I wanted to send several faxes and now with BB and no dial up I'm stumped, I'm guessing there must be a fax to BB piece of software out there...
Old 03-Mar-2005, 14:54   #3
No reason why you can't - as long as you have a modem and phone line you can send and receive faxes.
You will need to install the fax software, or use the built-in Microsoft fax manager software. You may need to install MS Fax Manager if it's not already. If you goto the Control Panel, then Add/Remove Programs and finally Windows Setup, it's in there.
Old 03-Mar-2005, 14:55   #4
Boys - nothing has changed. You don't need a dial up account to send /receive faxes!
You're just not using your modem for internet connection anymore, but keeping it for faxing.
Old 03-Mar-2005, 14:56   #5
I understand about the account thing. I was wondering if i can use the broadband modem to send faxes or do i have to keep using the old steam 56k modem?
[Edited on 3-3-2005 by rockhopper]
Old 03-Mar-2005, 15:00   #6
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
No, the broadband modem is going direct to the internet in WWWland via a seperate route. Your modem should still be seperatly connected to your telephone line (the old double socket thingumyjig) and when you send a fax, it's connetcting to the PSTN (Public Switched Telephone Network)
Rgds, Rob
Old 03-Mar-2005, 15:16   #7
Ahhhh... but for me, I never needed to fax until I went BB, so never had a fax/modem.
So I would either need to buy an old fax/modem PCI card or get some rinky dink s/w that can do it via BB/on-line service
Old 03-Mar-2005, 15:20   #8
I've been waiting for the ideal opportunity to use this because I nearly wet myself when I found it.
Old 03-Mar-2005, 15:21   #9
That's about the funniest thing, and the only sensible thing I think I've ever heard you say!
Old 03-Mar-2005, 15:24   #10
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:37.
