Old 04-Mar-2005, 00:46   #1
sparkin sparkin is offline
sparkin's Avatar
PC boffin help please
Simple question,how do you resize a gif?(an still keep it animated)
cheers
Old 04-Mar-2005, 10:53   #2
I haven't tried it on an animated gif but I assume it's still the same. There are plenty of free downloads or trial versions of software if you put 'image resize' into google.
Or even try www.tucows.com
Old 04-Mar-2005, 11:20   #3
ziggi ziggi is offline
ziggi's Avatar
If you want to display the gif image in a web page then you can use HTML to resize it on the page as so <img src="yourimage.gif" height="XX" width="YY">
If you are looking to resize it similar to a regular flat image then you won't be able to do this easily without the original images that made up the animated gif.
Download a gif animation software pack from download.com or similar. Open up the animated gif, you'll see that it's made up of a series of flat gif images that simulate the animation (like a flicker book). You might be able to save each image individually and then resize each one to the same dimension.
Now you have to re-assemble the animated gif image. Look at the original. Each image will have certain properties around it - copy each property and then resave.
Old 04-Mar-2005, 12:59   #4
If you've got some fancy software like ImageReady (part of Adobe Photoshop) it will do it for you and keep the animation...
Old 04-Mar-2005, 13:59   #5
Paintshop pro comes with a gif editor which is what i used to do mine.
Old 04-Mar-2005, 14:00   #6
sparkin's Avatar
Ah Ha! Got that antonye resized it now how do I set that as my avatar out of my documents or do I need to put it on a web site?
Old 04-Mar-2005, 14:17   #7
sparkin's Avatar
Ah Rockhopper! just the man,mine is a cartoon version of yours(I liked it so much I bought the company).I`ve resized it with image ready,but go to save it and it saves as photoshop doc,I`m nearly there,help me guys
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 03:15.
