Old 04-Mar-2005, 00:54   #1
sparkin sparkin is offline
sparkin's Avatar
Clutch bleeding help please
Even thou I`ve only just got me bike back I want to change the clutch hose to a stainless one.No problem changing it,not quite sure on the bleeding proceedure with a clutch thou.
Old 04-Mar-2005, 01:16   #2
Glyn Glyn is offline
Glyn's Avatar
Mood: st2......we can rebuild
lever in release nipple, tighten nipple pump lever hold in losen nipple tighten pump lever losen nipple tighten pump lever losen nipple tighten pump lever losen nipple tighten pump lever losen nipple tighten pump lever losen nipple tighten pump lever losen nipple tighten pump lever
just keep lever pulled in when you losen nipple
Old 04-Mar-2005, 02:05   #3
sparkin's Avatar
Is that the exact amount of times Glyn?
Old 04-Mar-2005, 08:54   #4
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
If you have a bleen nipple on the master cyl, bleed at the top of the run first. Once the cyl is pumping well, it's all plain sailing.
Old 04-Mar-2005, 11:57   #5
Rooney Rooney is offline
Mood: Need to get out
Glyn please don't use the words pump and nipple you know what Sparkins like
Old 04-Mar-2005, 13:38   #6
sparkin's Avatar
As I can`t do Cadwell did you fancy TA4.5 on the saturday 25th june?Just fancy putting the 888 beside your 998 down revit straight If it ever starts
Old 04-Mar-2005, 16:22   #7
[Benny Hill Sirry Iriot mode on] If Gryn been talking pump, nipple, pump, nipple like that, no wonder he made other post about having stiff clutch in the morning [/Benny Hill]
Old 04-Mar-2005, 17:52   #8
Yeh I got my form through this morning I would like to do Snett but got to get round the mrs some how mate .Its the going to Spain thing and Cadwell , I have got to get the extenstion and garden sorted this year mate so i will have to work on her But then again would it be a good thing having us in the same group me thinks not
Old 04-Mar-2005, 22:45   #9
crash crash is offline
Did mine a few weeks ago - complete bitch.
The hard bit is to get the master cylinder pumping. I used a syringe to pre-fill the hose, then made sure the master cylinder was bled at the inlet to the hose, and pumping (put your thumb over the outlet where the hose attaches, but be careful not to spray fluid everywhere).
Then attach pre-filled hose to master cylinder, and hey presto - you can then blead to your hearts content.
Crash
