Old 04-Mar-2005, 00:56   #1
HW HW is offline
Battery terminal fell off the cable!
I went to turn the alarm off on the 749 today and it was dead as a Dodo! It seems that the (very) short negative lead has meant that when I have taken the battery off the bike, which I did this week to try and get some charge into it in the warmth of the house, I have had to bend the angled terminal plate back to let the battery have enough room to manouver it out.
I am now praying that my local dealer can get me one quickly as it is only 3 weeks until first trackday.
Are they all that short that you have no room to pull the battery out, or has mine just got caught somewhere?
Henry
Old 04-Mar-2005, 09:13   #2
jobr jobr is offline
Mine is quite short, so I know longer take it out.
Ive got an optimate now and leave the connectors tucked inside the fairing all the time. Hence the battery is on "charge" the whole time I am not on the bike and starts first time without a problem. Cost about £35, bargain!
Old 04-Mar-2005, 09:30   #3
HW HW is offline
[sorry, this is long]
Yep, I have an Optimate and religiously plugged it in every time it went in the garage. The connector for the Optimate sits just near the clutch slave cylinder behind the fairing.
When we had that warm spell I tried to start it. Not enough charge in the battery to turn it over. It had been on the Optimate all winter and showed "green". The dealer suggested I would need to switch off and on again to reset the charger and bring it up to full charge, which kind of goes against everything I thought an Otimate was supposed to do! I did it though, several times, to trigger charging cycles and it still could not turn it over.
That is when I decided to remove the battery, get it somewhere (much) warmer and recharge it. Put it back o the bike and it started fine. Next day went to disarm the alarm and it was completey dead. Terminal had come off - presumably the last straw for it was passing lots of current to start the engine. The point where the terminal shoudl join to the cable looks very burnt, which if it had broken half off it would do.
I am now on a hunt for a replacement (phoning dealer today when they open) or better still make up a replacement cable that is a little longer or has a better terminal arrangement.
Henry
Old 04-Mar-2005, 09:43   #4
Originally posted by Dseered
Originally posted by jobr
Mine is quite short
Its all this cold weather.
Many people have commented previously on how I should think before I speak - another classic example.
Old 04-Mar-2005, 09:52   #5
HW HW is offline
Might have found an alternative solution - Demon Tweaks have loose crimp connectors. Also made up cables in 300mm and 600mm lengths that are only £2-30 each! Wouldn't mind betting that Ducati original is MUCH more than that, even if they are available.
http://www.demon-tweeks.co.uk/catalo...DE=A/ECTT16/10
Old 04-Mar-2005, 11:31   #6
HW HW is offline
Well that's a bit of a blow ... the battery cables are NOT available as a spare part from Ducati. Official. Be warned!
Looks like Demon Tweaks do angled and straight connectors for that guage calbe, and the calbes themselves. Pretty cheap. Need to either have right crimp tool or squash/solder them on (should be ok?). I just spoke to a mate who runs an electric car (god knows why!), but he solders them and that runs at 200 amp.
Henry
Old 04-Mar-2005, 12:52   #7
Then again, I know a couple of people who have had gel batteries (as fitted to the 999) replaced under warranty because they don't hold their charge.
Old 04-Mar-2005, 13:09   #8
HW HW is offline
Yep, that is quite common with that type of battery. The dealer admitted it too. They sais most battery manufacturers only give 6 months warranty, but Ducati cover it for 2 years.
I've just traced the earth cable back to where it bolts to the engine ... which is behind one of the trellis struts on the rear cylinder. I was just thinking that to get a straight run at the Allen head I was going to have to cut down an Allen key especially for the job, when I noticed that I could unsrew the earth terminal from the engine with my fingers. It was a couple of turns unscrewed already. Not good for 4k miles really.
How considerate of them to leave it loose like that so I didn't have to cut up my tools! (joke, it could happen to anyone, but making it hard to tighten up without the engine being dropped out the frame makes it likely to end up loose?)
The dealer said that they were always very tight like that (trying to get the terminal off the battery that is), but I can see how I can reroute the cable so it comes onto the battery at the right angle to be able to lift the terminal off, as you would normally expect to do. I am going to buy some rings and cable from Demon Tweaks (as it's convenient and I live in the boonies) and make up my own.
Anyone got any idea what current rating a 5mm dia cable is?
Henry
Old 04-Mar-2005, 15:00   #9
Felix Felix is offline
About 100 Amps.
Old 04-Mar-2005, 15:14   #10
HW HW is offline
Ta. Replaced with a made up cable from Halfords, plus a big solder terminal to poke all the other wires in that need to go with it (about half dozen or so).
Henry WILL make it to the ball (sorry, Track Day) after all.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:15.
