Old 05-Mar-2005, 22:39   #1
johnpick johnpick is offline
Mood: looking forward to summer
suspension woes
I think this is my first post so here goes.
I have a 1994 916 strada (monoposto)which runs showa front forks and ohlins rear shock.
My question is this can anybody tell me what the factory setting is for the suspension please.
Preferably in easy to understand format as I'm a bit thick when rebound and compression etc. The bike tends to bounce when going through sweeping corners. I dont have an owners manual so I can't refer to that.
Any help would be appreciated.
Thanks in advance
John
Old 05-Mar-2005, 22:46   #2
m1keyp m1keyp is offline
You can down load owners manuals from the ducati website unfortunately they do not go back to 1994 but they may help.
Has the suspension ever been serviced? at 11 years old it may be just old age
http://www.ducati.com/bikes/service/...modelName=2005
Old 05-Mar-2005, 22:47   #3
well, firstly welcome to the most useful and best supported Ducati club!!
There is a thread that has a link to a superbike site for setting up your suspension, I am sure someone will be along soon with it for you. You could try a search for suspension settings and you may find it that way. Sorry cant help more - technically innept you see.
Old 05-Mar-2005, 22:49   #4
suspension settings
http://www.mad-ducati.com/Technical/916Suspension.html
Old 05-Mar-2005, 22:49   #5
Sorry and welcome to the club
Old 05-Mar-2005, 22:52   #6
www.section8superbike.com
Old 05-Mar-2005, 23:38   #7
top guys all this info in less than an hour
I'm well impressed
Old 05-Mar-2005, 23:38   #8
Mr_S Mr_S is offline
Welcome aboard..
Settings for SP (Showa Front / Ohlins DU3420 Rear) FRom the owners manual.
Rear
Both adjusters all the way in (clockwise) then 14 clicks out
No preload value given - set for 30-35mm sag.
Front
Rebound (top of fork) 10 clicks out (CCW) from fully in.
Compression (bottom of fork) 12 clicks out from fully in.
Preload is 20mm (3rd ring from top)
Old 05-Mar-2005, 23:42   #9
Thanks in advance
John
your second post......:P
Old 06-Mar-2005, 01:39   #10
Dibble
Thanks in advance
John
nope, its his first post .. his 2nd is the one a few posts down from the start of the thread, hence a post count of 2 at the minute ......
John, depending on where you are theres bound to be someone local that can help or a suspension centre we can send you to .. I use HM Racing in Orpington ....
So fill in your profile and we'll get on the case .. you may find that spending a little money on a set-up is the best money you,'ve ever spent on the bike .. it was for me ...
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:30.
