Old 06-Mar-2005, 20:17   #1
its oh so quiet....
got the stadard cans on at the mo, for mot, and god its QUIET!
Leads me to belive (altho I kinda knew anyway) that termis need re-packing. Is this easy to do? Mate recons just remove rivets, bang in some new packing and re-rivet, simpple. Whaddya think?
Old 06-Mar-2005, 20:21   #2
keefer keefer is offline
keefer's Avatar
yes it nearly that simple.
as long as you get a good packing kit. i.e pucka termy kit, as it comes with all the mesh and wadding required.
then as you mentioned. drill of the rivets whip out the packing and whack it all back together using some wire to hold the new wadding in place
[Edited on 6-3-2005 by keefer]
Old 06-Mar-2005, 20:25   #3
TopiToo TopiToo is offline
Bikes: 748ish . .
Mood: Sampai jumpa lagi
Hello,
I am not sure but when I blimp the throttle sounds like I have a small metal screw in one of the end pipes. would it be safe to say "Theres the sign"
regards
TopiToo
Old 06-Mar-2005, 20:30   #4
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
Keefer's covered the repacking process, so...
TopiToo, take the silencer off and shake it!
Old 06-Mar-2005, 20:32   #5
keefer's Avatar
if you have the end cans of the bike, you can tip them up one way then the other. And if they make a sound like a kaleidoscope (sounds like sand inside)
then it would be a good idea to investigate further. also look for hot spots or burns.
I was once told by a dealer that they should be repacked every season, sounds a bit much to me but just bear it in mind
Old 06-Mar-2005, 20:33   #6
keefer's Avatar
Originally posted by TopiToo
Hello,
regards
TopiToo
could also be a loose rivet
Old 06-Mar-2005, 20:59   #7
Bikes: 748ish . .
Hello,
I am thinking it must be a rivet which must mean something amiss, thanks for the the advice NickB34 and Keefer,
will look into it.
Bradders if possible let me know how you get on, may well be looking at doing the same "need re-packing"
regards
TopiToo
Old 06-Mar-2005, 21:58   #8
cool...now to find a re-pack kit....
[Edited on 6-3-2005 by bradders]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:30.
