Old 08-Mar-2005, 09:43   #1
Tantrum992's Avatar
multistrada display misting
i own an ex-demo 03 multistrada which has had its fair share of problems but have allways been sorted fairly quickly buy my local dealer Veloce, i keep reading references to dashboard misting and am concerned that i may have a problem with mine, over the 10 months i have owend the multibeast the dash has misted several times but always cleared at various speeds, is this something i should be concerned about, any thoughts appreciated, the warrenty is due to exspire in the next month or so.
Old 08-Mar-2005, 10:27   #2
dave s dave s is offline
Mood: not a happy bunny
There has been a problem with the displays on the multi's misting over and as far as i know they have been changed under warranty so my advice would get it changed while you can.
Old 08-Mar-2005, 11:14   #3
It's only held together with several plastic clips, inside the assembly is a small rubber seal, could be that...
Old 08-Mar-2005, 11:32   #4
DSC Member AK AK is offline
AK's Avatar
and also some monsters too!
My M1000 had the same - clocks changed under warranty by dealer, no probs at all
(M750ie had the same prob - replacement clocks on that too!)
C
Old 08-Mar-2005, 11:35   #5
My 620 clocks did that - they dried out on Sunday but it was definitely annoying!
Old 08-Mar-2005, 18:29   #6
Tantrum992's Avatar
its unanimous then, back to the dealer on saturday for a new dash, thanks for your comments/advice
Old 08-Mar-2005, 19:35   #7
sparkin sparkin is offline
sparkin's Avatar
Been there,done that:P
The problem is Simon,if it mists up to bad the bike will stop!I had three on mine in six months.The later ones have different seals fitted and a resistor type thingy to make the fuel guage react slower as it swills around the tank(especially when passing 998`s )
The first sign is normally the green indicator warning light in the dash staying on.Go see John or ring him and tell him what`s happened,it`s only a ten minute job to change,three bolts and a key reprogramme,he can do it with his eyes shut he`s done so many
Old 09-Mar-2005, 01:09   #8
MARTIN H MARTIN H is offline
MARTIN H's Avatar
Yes, mines just started doing it now! Faint green light showing and the display virtually unreadable. Knowing the problems with these units I have done everything I can to keep it dry. I am now expecting the bike to develop the famous brake shudder everyone talks about!
Old 09-Mar-2005, 18:39   #9
Tantrum992's Avatar
Martin H
which green light is showing ?
Old 09-Mar-2005, 18:42   #10
sparkin's Avatar
The one which tells you you are indicating!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:00.
