Old 14-Mar-2005, 01:29   #1
sharpo sharpo is offline
sharpo's Avatar
Mood: Big bill-money well spent
Electrical problems.......help.
OK so while I was cleaning the bike I noticed the two yellow cables from the stator to the regulator had been very very naughty.
Does anyone know of a good replacement for this plug.
I'm glad it's not taxed or i'd have been out on it.
Old 14-Mar-2005, 01:31   #2
sharpo's Avatar
And another
Old 14-Mar-2005, 01:40   #3
Mr_S Mr_S is offline
Solder them together
If I remember right the plugs the problem, although the gauge of the wires could be increased too.
[Edited on 14-3-2005 by Mr_S]
Old 14-Mar-2005, 01:45   #4
The gauge of the cable running from the alternator is a little low. It's possible to rewire this with heavier gauge but means the LHS engine cover needs to come off.
My preferred method of repair is to cut the cable back to good, and fit and crimp bullet connectors on. Apply electrolytic grease, connect and wrap in tape.
Soldering is all well and good, but it makes servicing a pain in the **** because you can't get the regulator/battery tray out of the way to do the belts etc. properly. It just hangs there and get's in the way
Not a big problem................but have a thought for your mechanic
Old 14-Mar-2005, 10:40   #5
Ooops, sorry Neil..
Old 14-Mar-2005, 16:51   #6
Mike Davis Mike Davis is offline
Mood: Shiney
You could also try Electrex world, they do all the replacment connector blocks. Hav`nt got a number but a search should give their website with all the contact details.
Old 14-Mar-2005, 19:46   #7
chrisw chrisw is offline
Bikes: 999 Mono/1198S
chrisw's Avatar
Connectors
The attached do a good range of connectors (including the Ducati type). They have a connector rated at 75amps on page 19 that should suit your needs (it is designed for large cables but would be suitable)
http://www.autoelectricsupplies.co.u...atalogue_3.pdf
Old 14-Mar-2005, 20:17   #8
sharpo's Avatar
Thanks lads.
I'm a leccy so i'll sort it one way or another.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:12.
