Old 14-Mar-2005, 15:23   #1
Carb Oil heating pipes
I have just fitted a different engine into my 600SS and it came with Dynojetted carbs that use the oil heating circuit to stop the carb Icing. My intention is to fit the float bowls off my original carbs. So what I want to know is what is the best thing to do with the oil pipes from the engine.
a, I could just blank them
b, I could just loop them
C, I could try nd fit a oil cooler between them
Any thoughts on the above please.
Old 14-Mar-2005, 15:28   #2
Redruth Redruth is offline
Redruth's Avatar
Mood: Fabulous
No
Old 14-Mar-2005, 15:41   #3
Ruth how long did you rack your brain for to come up with that answer.
Old 14-Mar-2005, 15:43   #4
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
If you could use them to hook up an oil cooler then surely that's the way to go. Seems like something to take advantage of.
n
Old 14-Mar-2005, 15:53   #5
Harv748 Harv748 is offline
Harv748's Avatar
Up to the handlebars...heated grips?
Old 14-Mar-2005, 15:57   #6
DSC Member AK AK is offline
AK's Avatar
oil cooler - carb icing still poss at end of April!
Old 14-Mar-2005, 18:54   #7
fil2 fil2 is offline
fil2's Avatar
Mood: is it still wet
I really hope not.......cos it is a MAJOR hassle ...believe ME
phil
Old 14-Mar-2005, 21:54   #8
Hmm yeah but its only a problem at low rpm.You guys will be WFO most of the time,............apart from the Cadwell woodland hairpin!
What you need is a splash of Silkolene Pro FST in the tank.
[Edited on 14-3-2005 by KeefyB]
Old 14-Mar-2005, 22:11   #9
monstermob 998's Avatar
pro FST with shell advance petrol carb icing is history plus feels like a slight power gain when using shell advance - any one else noticed this???
Old 14-Mar-2005, 22:57   #10
I think I'd be tempted to just blank 'em off for the mean time - using the 'keep it simple' rule!
good luck - Frank
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:45.
