Old 17-Mar-2005, 11:11   #1
fatduke11111's Avatar
Help overvoltage?
The Bip has been really slow in turning over so I thought I check the normal stuff like voltages (to see if the regulator has not gone awol) - I've got some very strange readings from the digi voltmeter.
Across the Battery getting 12.9 - 13.0 v no engine running
At tickover I was getting 16.5 - 16.7v and above 3k rises to around 17.4v?
This sounds a bit odd to me - the starter still turns over like a dog though and after a spins won't turn the engine over at all - any thoughts, anyone?
P.S. the connectors look good from the regulator i.e. no burning or crap....
FD
Old 17-Mar-2005, 12:08   #2
Felix Felix is offline
If you're measuring this across the actual battery posts/terminals, then I would think the battery's had it. A good battery would allow the voltage to rise that far. It would absorb it as a charge.
Old 17-Mar-2005, 12:48   #3
Felix:-
Yep, across the terminals...good point I'll nick the batt off me ST and try it out.
I noticed that the +ve to the starter solenoid was a bit warm as well! I've also just changed +ve, -ve leads as well so I'll see what happens....ta...
Seems to spin a bit better.
FD
Old 17-Mar-2005, 12:51   #4
...I changed them to a higher guage not swapped them over......
Old 17-Mar-2005, 14:45   #5
Knackered regulator putting out 17 volts has wrecked the battery. Swapping batteries will just wreck the new battery as well.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:49.
