Old 30-Sep-2012, 09:47   #1
pguenet pguenet is offline
FS - 996 RS / 998 RS / 998 s parts
Right, now that the 998 is on the bench ready to be disassembled, I am advertising the parts that will be going up for sale soon.
Parts are 998RS / 998s but some of them will make their way to the 996, hence why you have some 996RS in there too.
Parts are noted with price.
Parts noted with interest may fall through still, so inquire if that is of interest.
Photos available on demand.
- spare 998 RS radiator - some repair at top - £400
- 998 RS radiator (on bike - better condition) (interest)
- 998RS cooling pipework (Alloy + Samco) 350
- 998 Nemesis ECU - with disc and cables - £550
- 998 standard oil cooler - quite a few fins bent - £30
- 999 standard master cylinders - £100
- RS gear shift pedal (reserved)
- 999 throttle bodies with airbox - £120
- 996 RS 60mm throttle bodies adapted to fit 998 RS (Single Shower injectors) (interest)
- 998 RS manifolds - (interest)
- 998 RS Yokes refurbished
and
- 996 RS Yokes refurbished
One set will come with Ducati RS steel excentric (£1800), one set will come with exact replica excentric made in Alloy 7075 like the factory bikes (£1400)
Choice of :
- FG9760 radial mount 996 RS / 998 RS 46mm race ohlins - needs servicing, complete (** note I favour keeping those forks) £4,000
- FG9750 axial mount 996 RS 46mm race ohlins - recently serviced (some mudguard mounts missing, but could get those machined at cost) £3,000 without the bits
I also have the 40 mm axial mount monoblocs for them £1500
- Front axle wide track £100
- Red RS Mudguard wide track £150
- 998 RS - 10 spoke magnesium wheels – refurbished Black (16.5) £900
- 996/998RS - 5 spoke magnesium wheels – refurbished Grey (16.5) £700
- 996RS / 998 RS - Dymag magnesium rear wheel – Black (16.5) £220
- 998 S Frame with v5 £550
- 998 RS carbon front subframe (interest)
- 998S throttle bodies with Racing bellmouths (gain 4/5bhp) £650
- 998 RS MF3S Magneti Marelli ECU – will be reprogrammed, discount if buying as is. £1500 reprogrammed
- Rear 996 RS Suspenstion Rocker £380
- Rear Ohlins Race shock for longer RS swingarm £650
- Rear Race ride height adjuster model with central adjustement like RS bikes £150
- Rear brake caliper mount for small hub / race caliper £150
- 996RS Rear billet Brembo brake caliper £450
- 998s Very tuned engine which I will part:
Starting with Gasflowed and ported heads with 749R cams (higher lift) + and 102mm rebored barrels (Ducati Kamna) and 102mm Pistal Pistons giving 998 / 999 engine a 1038 capacity. You will get between 160bhp and 170bhp with this. Looking for £1500 for Heads + Barrels + Pistons
Prices may be discussed but not by much.
Prices are without shipping
Shipping from the UK at cost
Payment via transfer or Paypal (but you add the 4% fees).
thanks
p
Old 08-Oct-2012, 07:35   #2
- spare 998 RS radiator - some repair at top - (now sold)
- Other one available.
- 998 RS manifolds - (now available) - £400
Some pictures below
Old 08-Oct-2012, 07:37   #3
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:25.
