Old 18-Mar-2005, 00:10   #1
999 Ohlins setup
Following on from my last thread...
Anyone got any settings for full ohlins on a 999? preferably biased towards the track
Would it be worth using the settings off the Bostrom on the 999? I am assuming that Ducati kept the same geometry on the 999 as the 998... why change a winning formula?
Or would this be a BIG no no....
I await Dibble to say "just ring JHP"
Old 18-Mar-2005, 00:12   #2
Dibble
[i]
well it's better advice than "phone Adam" ..
Old 18-Mar-2005, 00:46   #3
My understanding is that the weight Bias is different between the newer bikes (999) and the older bikes (998), as such you may find the suspension has different spring rates and would therefore have damping to suit.
http://www.section8superbike.com/749-999suspension.htm
Old 18-Mar-2005, 01:04   #4
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
I know what JHP would say, " have the forks re-shimed with 25mm shims"
A snip at 200 plus notes. Me I would go to Ktec
Old 18-Mar-2005, 02:56   #5
chillo chillo is offline
chillo's Avatar
i've got a fairly good set-up on mine, will check as i can't remember off the top of my head.
Old 18-Mar-2005, 09:55   #6
Felix Felix is offline
K-Tech is it.
Old 18-Mar-2005, 11:45   #7
Chillo cheers for that, got to be worth a try before I go shelling out any more hard earned!
Old 18-Mar-2005, 11:56   #8
Goofy_DK Goofy_DK is offline
http://www.ohlins.nl/products/ohlins_sussetup.html
Maybe no help...but
Old 18-Mar-2005, 13:32   #9
BDG BDG is offline
BDG's Avatar
Jon
i guess your probably at work at the moment, and time is tight but it would be well worth running over to KAIS, which as you say is only 30 mins from you and getting it set up to suit.
Even if you can't do it today, how about explaining the prob to Andy and even booking it in for crack of dawn tomorrow, i know this means missing the early part of the track day tomorrow BUT it may be better to do half a day with confidence, rather than a full day with doubts in your mind in view of last Sundays slip off (which i really believe is down to a combination of stone cold tyres and the masses of salt dumped on our roads of late).
KAIS are on 01942 896366 and speak to Andy (tell him Ron Williams sent you!) I did and he nearly had a fit
Old 18-Mar-2005, 14:12   #10
Shaun,
I know Andy of old, he sorted the suspension on my 996 several years ago, might be worth me calling to see if he has any good base settings, I doubt I'm going to have time as both of our bikes will be in the van, and it's not fair to deprive Lily of her track day at the end of the day
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:53.
