Old 09-Jul-2003, 12:41   #1
DJ Tera DJ Tera is offline
False neutrals
I did Snetterton yesterday, and at least every other lap I would get a false neutral going from 4th to 5th, at one point I had to try THREE times to get it into gear, bike is only 10 months old surely the gearbox isnt sh@gged already?!
Old 09-Jul-2003, 16:17   #2
Damo748 Damo748 is offline
This sounds similar to the problems that Rattler had?
Old 09-Jul-2003, 18:38   #3
andy bentley andy bentley is offline
you got frame plugs in?
If you have, check that the lever has some clearance when moving up. I was getting them and it was the frame plugs getting in the way - bought them via DSC too. There was nothing wrong with the lever adjustment, just needed bending out a bit.
Andy
Old 09-Jul-2003, 21:16   #4
It happened when nailing it on the two long straights, i wasnt caning it on the first two laps of every session, and it only happens when i was going for it, had to give it a good kick up the arse to get it into fifth
I've had frame plugs for 6 months now, this is the first time I'm getting false neutrals (apart from sometimes going from 1st to 2nd - but dont "they all do that sir?")
Old 09-Jul-2003, 22:15   #5
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
DJT were you useing the clutch.
If so next time try without.
Jon
Old 10-Jul-2003, 08:06   #6
On that note, when I did Donny earlier this year I was surprised at how well the Ducati did the clutchless gear shift. It was a lot smoother than it was on my Kawasaki.....
Old 10-Jul-2003, 13:31   #7
yeti yeti is offline
yeti's Avatar
Clutchless upshifts are the way to go. Never seen the need for a quick shifter when you master this technique. cannot believe mere mortals would ever benefit from a quickshifter.
Old 10-Jul-2003, 14:26   #8
Will using the rev-limiter as a quick-shifter f*ck my engine/gearbox up? I'm asking cos the dyno chart i have shows my bike making peak power at 10K, and it doesnt drop off after that either!
Old 10-Jul-2003, 16:33   #9
Felix Felix is offline
I was of the same opinion, Yeti. Until I tried the one that came on my bike. WOW! Being able to keep the throttle pinned, as you can with the quickshifter makes a huge difference!
Old 12-Jul-2003, 20:52   #10
iainzx iainzx is offline
Mood: HELL YES !!
DJTerra, this might sound a bit daft but if the shifter is located in too high a position it does make it more difficult to give positive up-shifts - try lowering the position of the gear shifter downwards towards the ground ie in an anti clockwise arc around its pivot point this will give your foot more leverage for the upward change and more pressure for the downward change. it made a big difference on my mine
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:43.
