Old 20-Mar-2005, 19:58   #1
hooley hooley is offline
hooley's Avatar
Mood: One day I'll be allowed out to play......
LED Indicators - problems - help required
Just bought some LED indicators from Hein Gericke (the arrow shaped ones for 13 quid each)
Added the rear, including the resistors and with conventional fronts the speed of the 'winks' is twice the normal rate
Once I add the fronts (not with any resistors), nothing. No indicator action at all.
Anyone got any ideas?
When speaking to the Hein Gericke manager he said only one resistor is required per side
Cheers in advance
Jason
Old 20-Mar-2005, 20:04   #2
748mart 748mart is offline
What is the resistor value in Ohms?
Are you connecting the resistor in paralell with the indicator?
Old 20-Mar-2005, 20:10   #3
hooley's Avatar
Looking in the H-G catalogue it does not give an ohm rating, but states:
10 resp 21w resistor
Resistor is in-line on the +ve lead
Old 20-Mar-2005, 20:16   #4
The resistor should be across the indicator (paralell), not in line with it(series).
Old 20-Mar-2005, 20:25   #5
hooley's Avatar
Okay, i'll give it a go, but if you're wrong you owe me a fuse........
If you're right - I owe you a beer...
Jas
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:32.
