Old 20-Mar-2005, 21:06   #1
Chain guard - do we need for ACU regs?
I know we need the lower protector (under the swingingarm) but do we need a the chainguard that goes along the top of the chain?
Ta
Tim
Old 20-Mar-2005, 21:08   #2
Ta !
Old 20-Mar-2005, 21:17   #3
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
What I understand it you need a guard at the two points where the chain approaches the sprockets... so the front sprocket needs to be protected,as does the bottom of the back sprocket, but not the top of the back sprocket.
Old 20-Mar-2005, 21:36   #4
1.7.8 The Following Items MAY BE Removed
Chain guard as long as it is not incorporated in the rear fender.
I've been wondering about this rule,
now is the rear fender the hugger, if that is the case then the 600SS does not incorporate a chain gaurd with it where as the Monster 600 does
Old 20-Mar-2005, 22:10   #5
I'm a muppet and didn't read the first post properly !
[Edited on 20-3-2005 by phoenix n max]
Old 20-Mar-2005, 22:17   #6
But why do I need a rear fender? I assume (like you) that this means hugger????
Old 20-Mar-2005, 22:19   #7
Originally posted by phoenix n max
Acu rules state a chain guard must be fitted to prevent trapping between the lower chain run and final drive sprocket to the rear wheel.
You do need a lower chain guard.
Something like this :
http://cgi.ebay.co.uk/ws/eBayISAPI.d...0927 253&rd=1
I've got that one sorted, but do I need a guard above the chain was the question?
The monster's chain guard is fitted as part of the hugger, can I remove the hugger and chain guard, or do I need both??
I'm gonna fire a question off to desmodue@ducatisportingclub.com I reckon - I'll post the response.
Tim
Old 21-Mar-2005, 22:05   #8
DSC Member AK AK is offline
AK's Avatar
Tim - did you get an answer from your email?
It was one of the questions I was going to ask on Sat night, but it was too noisy.
Alan
Old 21-Mar-2005, 22:38   #9
I did - the response I got from MW was;
"following a bit of discussion ... u can remove the 'upper' chain guard along
with the rear hugger ...
hope that helps"
Tim
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:26.
