Old 21-Mar-2005, 20:48
A900SS A900SS is offline
Vibrating Wing Mirrors
Hi,
My wing mirrors have taken a turn for the worst. they were never that great but they REALLY vibrate now and I think they must have loosened up internally. Is there any way to tighten them up? Tightening them up to the fairing dosn't make any difference.
a900ss
PS 1998 900ssie
Old 21-Mar-2005, 21:31
FiscusFish's Avatar
Remove them from the fairing and you'll see a screw inside them. Undo the screw and the ball joint should come apart. Roughen both parts with coarse sandpaper then re-assemble.
You can even replace the screw with an allen bolt if you really want to tighten the joint up.
If you do a search for mirrors in the SS forum you'll find more answers.
Darren
Old 21-Mar-2005, 22:10
monstermob 998's Avatar
i sorted the vibration problem by twisting the throttle a bit more vibration dissappears at about 5000rpm
Old 22-Mar-2005, 09:49
Derek's Avatar
Derek Derek is offline
Bikes: ST4s ABS
Check your fairing screws are all tight. Mine seem to have a habit of coming loose, especially the upper rear screws on the fairing lowers. I've managed to loose the screws and the fancy washers twice in the last 5 years.
The first signs are that the mirrors vibrate more than normal.
Old 23-Mar-2005, 23:58
crash crash is offline
All SS mirrors seem to do this - particularly the left one for some reason.
When you tighten up the inner screw, try a drop of loctite - it stops the screw loosening with vibration.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:20.
