Old 25-Mar-2005, 09:49   #1
mogwai mogwai is offline
mogwai's Avatar
Mood: IF IN DOUBT..GET BLAGGING.
Speedo drive....
Does anyone know the easiest way to get at the knurled bit,to dis-connect the drive ?,what a twunt of a job...!
mogwai@bareknuckles.com
Old 25-Mar-2005, 10:02   #2
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Which end, I assume your talking the top, at the clocks.
Old 25-Mar-2005, 10:36   #3
mogwai's Avatar
No,wheel end...
Old 25-Mar-2005, 10:38   #4
Dunno, but I'm about to do the very same thing...If I find an easy way round it, I'll let you know.
Old 25-Mar-2005, 10:51   #5
Rob B's Avatar
On the wheel end, if the drive is too close to the fork to get a set of grips to the knurled ally, slacken the wheel spindle a couple of turns. That'll allow the speedo drive to rotate (the axle acts as a big pinch bolt). Once you've rotated it slightly, you should be able to grip it OK.
Hope this makes sense and helps.
Rgds, Rob
Old 25-Mar-2005, 10:52   #6
mogwai's Avatar
Morning Jools,please do keep me informed...think i need to get to get two pairs of long-nose pliers,as the knurled bit goes into a threaded part,which in turn goes into the drive and the two are turning together,when i think that the threaded part should stay still in the drive...
Old 25-Mar-2005, 10:55   #7
mogwai's Avatar
Aha !,cheers Rob !
Old 25-Mar-2005, 13:03   #8
Mine was easy in the end, bit of rag wrapped around the knurly bit to protect it, pair of pipe grips, quick twist, job done.
The threaded bit isn't supposed to turn as well though, that is a problem Moggers.
My speedo drive is OK, but the speedo cable is snapped. Only had the tiniest stub of cable sticking out above the threaded portion, just enough to drag it out.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:05.
