Old 25-Mar-2005, 17:52   #1
Mr C Mr C is offline
What the hell happend here?
Got about 5 miles in to a ride today and noticed that above 5000 rpm the clutch was slipping. So i just presumed that my Ferraci Slipper clutch had come to then end of its life. Till i got home opened it up and saw that the spider spring has shed 4 of its legs. And there was quite a bit of grease in there too
Question 1, How can this have happend?
Question 2,Will i have to buy a complete new clutch?
Thanks in advance
http://img.photobucket.com/albums/v6...ey/Clutch1.jpg
http://img.photobucket.com/albums/v6...ey/Clutch2.jpg
[Edited on 25-3-2005 by Mr C]
Old 25-Mar-2005, 17:58   #2
keefer keefer is offline
keefer's Avatar
have seen this on a few other bikes on the site.
something to do with to much pressure on the spring maybe.
you can get just the spider spring but you will want to find out why it has broken in the first place or it may happen again.
mine has never broken so hopefully someone's who's has will be along in a mo to tell you the remedy.
I know Yeti's went recently so drop him a note
Old 25-Mar-2005, 22:57   #3
ziggi ziggi is offline
ziggi's Avatar
I think I read somewhere on this board that the spider spring is to be replaced every time the clutch is pulled apart and reassembled.
Old 25-Mar-2005, 23:00   #4
Think the spring only has a certain life span Paul, as has been said already.
Think they're about £30-40 to replace, the hardest part will be torqing the nut up!
Old 26-Mar-2005, 12:08   #5
It's not uncommon. The spring either fractures through fatigue I guess, or loses it's "springiness" over time. Mine did it last year.
You may not have to stick witht he FBF spring as they are pretty much standard across different manufacturers, just make sure the ID is the same size as there are two different ones in use.
Old 26-Mar-2005, 12:34   #6
I have a spring from an FBF slipper that went south (the bearings disintegrated). As previously mentioned you may be wiser buying new but your welcome to it as a temporary measure.
Old 26-Mar-2005, 12:40   #7
Cheers dukess very kind offer, I think its best i grab a new one and battle with torqing it all back up!!!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:31.
