Model Specific - Discussion, Technical Problems and Help
998 / 996 / 916 / 748
> Weeping Steeringh Damper
26-Mar-2005, 09:16
small boy
Hi,my steering damper is leaking fluid when it turned left,can you put a new seal in,if so ,how much oil do you put in,how do you do it is what i am realy askig ?
small boy
Send a personal message to small boy
Find More Posts by small boy
26-Mar-2005, 12:08
neil748r
If it's an Ohlins damper then yes it can be serviced/rebuilt, not so sure about the stock dampers. Maybe an excuse to upgrade?
It's def not a DIY job! Any suspension specialist should be able to do the job. My recommendation would be K-Tech, Tel: 01530 810625.
Cheers, Neil.
neil748r
Send a personal message to neil748r
Find More Posts by neil748r
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:05.
