Old 29-Mar-2005, 17:10   #1
HellOnWheels HellOnWheels is offline
Changing clutch
Hello
At last the spring is coming to Norway, so now its possible to ride my duc here
Found out in the winter that my cluch was worn out, so now I`ve ordered new Clutch plates and are ready to change em... The thing is...how?....
I was wondering is any of u guys have a link to a page with some guidance how to do it?
Btw...I got a 2001 748R Red of course....
Thx
Old 29-Mar-2005, 17:14   #2
Dibble
oh, thats easy ....
take off the clutch cover.
undo the six bolts holding the springs on.
take out bolts, springs and caps.
Gently pull the pressure plate out and the pushrod will come with it.
You can then remove the plates.
Put new plates in (ensuring they are in the right order of plain and friction plates)
Then put it all back together.
About half hours work.
Old 29-Mar-2005, 17:30   #3
Thanks alot for your reply
Guess I`ll try to change it tomorrow. I was abit afraid that some springs or something would come out and be a pain in the a** to get back if not done the right way.
Please feel free to post if u know something special I before I start...
Thx
Old 29-Mar-2005, 17:33   #4
Dibble
no, it really is that simple, even i've done it .....
Old 29-Mar-2005, 17:34   #5
Pretty much as Dibs has said, just make sure you put everything back in in the same order you removed them. You should keep all the steel plates in order and note where the indented tab is on each steel plate etc also.
If you have a digicam might be worth snapping as each plate is removed, might be over kill but if you're unsure it's better safe than sorry
[Edited on 29-3-2005 by JPM]
Old 29-Mar-2005, 17:35   #6
Dibble
oh and when you put the pressure plate on make sure the notched hole lines up with the arrow .. it will all make sense as you take it to bits ...
Old 29-Mar-2005, 18:05   #7
Thanks alot for the replys
U really make me feel like doing this right now
One more thing I wonder about.... How tight shall the screws with the springs be fastened approx? And Locktight etc?
Thx
Btw.....Nice avatar...
Old 29-Mar-2005, 18:07   #8
I've never loctited the bolts on the springs, the force pushing on them via the spring keeps them in place. As for torque settings someone will come along with the exact figure, me being a luddite I just tighten them pinch tight and never had a problem.
Old 29-Mar-2005, 18:07   #9
Dibble
do not loctite the clutch spring bolts, just torque them up solidly by hand .. overtightening isn't needed.
Old 29-Mar-2005, 18:24   #10
moto748 moto748 is offline
And, worse than that, you can shear the "turrets" off if you overtighten them.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:31.
