Old 01-Apr-2005, 14:01   #1
swannymere's Avatar
Mood: High as a kite!
Wiring tube on exhaust
Hi,Nick from Meon Valley,i have an 03 749BP to which i have fitted a genuine mono subframe and termi assy pipe.I am having a problem with the tube that carries the wires fitting into the channel in the bottom of the termi can,it does'nt follow the curve correctly and fouls the subframe slightly when it ends.Any ideas?
Old 01-Apr-2005, 22:41   #2
Hmm,mine fitted ok when I swapped subframes.Are you sure you have it positioned correctly?
Old 02-Apr-2005, 00:57   #3
swannymere's Avatar
The subframe bolted straight on,no tight bolts or anything,same with the exhaust.I can only think that i may have bent the tube at some point.I'll try a different approach next week,i thought i'd ask to see if it was a common problem.No worries
