Old 05-Apr-2005, 00:46   #1
sonic sonic is offline
Mood: bleedin ecstatic!
Tank Scratches
Anyone have suggestions on how to avoid tank scratches on a 749. Ive got the Dark version, so any tiny little mark shows up like Ive taken a maschete to it.
Ive seen some retro fit ducati original tank protector, cut in the middle and 'stretched' across the standard one. Have heard of these thin plastic stick on sheets you can have also (but one be visible on mine as its matte).
... and no... im not on par with vanessa feltz before you mention it
Its the bit underneath the current protector where my legs rub against it, and slightly above too. God. Maybe I do need to diet. *puts down the last of the easter eggs*
Old 05-Apr-2005, 01:01   #2
get a carbon one and stick it on using black silicone. WFM
Old 05-Apr-2005, 10:53   #3
sbwells sbwells is offline
sbwells's Avatar
Mood: Bring the noise!
Sonic - Same problem mate. Think I need to go on a diet
Old 05-Apr-2005, 11:33   #4
andyb, would still be the same though wouldnt it? The replacement carbon item still only covers the same area as the standard one. I need to cover more bits so just wondered if there was a way. Ill try to find the picture from MCN site to show you what this guy has done...
Old 05-Apr-2005, 13:44   #5
Wylie1 Wylie1 is offline
Wylie1's Avatar
I know this is going to sound stupid, but sit a bit further back in the seat. You should have a gap about as wide as a packet of 20 fags between the family jewels & the tank. The shape of the seat makes more sense & it's a lot more comfortable because it doesn't dig into the underside of your thigh (although it does put more weight on your wrists).
Old 05-Apr-2005, 13:51   #6
tricky tricky is offline
Mood: Need spares
I've found of I sit that bit further back its a greater distance to travel to knock the jewels when you go over a good bump and it hurts more
As for the tank protection I've stuck a couple of those dot type tank protectors underneath the factory protector and put a motograffix tank pad above.
Old 05-Apr-2005, 14:03   #7
Wylie1's Avatar
At least it doesn't scratch the tank though!!
Old 05-Apr-2005, 14:13   #8
trickz, dont suppose you have a piccie of it do you (not that I wanna nick your idea or anything
Ive tried sitting further back, at all different angles etc but still tends to stratch it... if you sit further back, your gonna end up forwards when you brake anyway, so if anything, its gonna stratch more when you 'fly' towards the ball breaker.
Heres what someone did on the MCN site...
[Edited on 5-4-2005 by sonic]
Old 05-Apr-2005, 14:25   #9
Wylie1's Avatar
Sonic....have a look at this link:-
http://www.tankpads.com/productsbycat.asp?cat=00&sub=12
It's the best solution I've seen
Old 05-Apr-2005, 14:32   #10
well bugger me, they make one, cheers Wylie!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:19.
