Old 05-Apr-2005, 10:07   #1
Founder Member
Paul James's Avatar
Speedo drive spacers
I've been asked by one of the entrants to make up some bits for his bike, one item which may interest others is a spacer to replace the speedo drive on the front wheel. It should make wheel changes easier. This fits a 20mm spindle and is 35mm long, if this fits your bike (depending on model) and you'd like one in Aluminium they will be a fiver each if you send me a jiffy bag with stamp and address on.
Anybody stuck for turned parts for the bikes or proper thread inserting just get in touch.
Best email direct at ducatiman@btconnect.com if interested.
Old 05-Apr-2005, 10:22   #2
Anyone who knows the models enough to say which this will fit?
It'll save me heading outside with the micrometer....
Old 05-Apr-2005, 22:15   #3
Founder Member
Paul James's Avatar
i doubt if they differ much but any info would be helpful. Will need to know interest by Friday so I can get on and do the machining.
Old 06-Apr-2005, 00:05   #4
Will deffo have one Paul - at that price it doesn't matter if it doesn't fit!
Old 06-Apr-2005, 00:55   #5
At 35mm wide with a ID of 20mm and a OD to suit then they will deffo fit the 1996/7 600SS, as I have already made a couple of nice Alloy ones for mine and Senna3's bikes.
Old 06-Apr-2005, 09:52   #6
Founder Member
Paul James's Avatar
Thanks for the info Skids, I guessed it might be a fairly standard part.
I've been offering a thread repair service for some time now, I hate helicoils so when I was racing sourced some fantastic solid inserts. As my engines were regularly stripped and rebuilt I put inserts in to the cases at vulnerable points which made working on them much easier. It can rescue damaged castings which you might otherwise have to chuck away !.
Anybody interested just give me a call.
Old 06-Apr-2005, 10:53   #7
fil2 fil2 is offline
fil2's Avatar
Mood: is it still wet
deffo have one of them have sent u an email
Phil
Old 06-Apr-2005, 17:32   #8
Fitted mine this morning after finishing off the fork rebuild, looks a lot nicer than the speedo drive. Another couple of jobs off my list, now back to the garage.
Old 06-Apr-2005, 17:37   #9
Been out in the garage myself and not having the speedo drive will make the carbon dash look a lot better
Old 06-Apr-2005, 21:27   #10
Founder Member
Paul James's Avatar
Erm, it doesn't fit there mate, it goes on the wheel spindle ??
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 00:06.
