Old 09-Apr-2005, 11:48   #1
Ericsson Ericsson is offline
748R Frame and Testastretta motor ?
Hi I read this somewhere about a 748R frame:
Compatible With 748R - 996R Testastretta - 916SPS Fogarty Replica
I thought that the testastretta has 12mm framebolts instead of "old" 10 mm.
So does the 998 engine fit without modification to the frame?
Old 09-Apr-2005, 11:55   #2
Skidlids is the hybrid expert...ping him a U2U
Old 11-Apr-2005, 00:19   #3
Webcore Webcore is offline
I've just had a 996S engine put in my 916 by Moto Rapido, they sleeved the 12mm mounting holes in the engine and used the 10mm bolts.
Old 11-Apr-2005, 01:22   #4
As Jools mentioned I have my Hybrid which is a 748RS frame fitted with a 998Bp engine, both the frame and engine use 12mm engine bolts as standard.
I can check my 748R engine sometime to see if that has 12mm engine mounts.
You need a bit more than just the engine though, I also fitted the twin fan rad, oil cooler and pipes, harness, Airbox and repositioned the coils.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:05.
