Old 27-Oct-2012, 20:57   #1
mowglistromboli mowglistromboli is offline
mowglistromboli's Avatar
External fuel pump
Currently building up my class b bike for 2013, just wondering how many people run external aftermarket fuel pumps or if the standard ss unit is good enough? What pressure does the pump run at / what does every one else run?
Any help would be thankfully recieved.
Old 27-Oct-2012, 21:04   #2
Standard SS pump has proved OK and is what I'm using on the Class B bike I'm building. Even the Vacuum operated pump on the Monster 600s works OK, although a couple of people have replaced them with pumps from other carb'd bikes like Yam R6, CBR600 (mid 90s models) and ZXR400s.
Never measured the pressure on these as its quite low as they only substitue a gravity feed
on the injected class A bikes a 3-Bar bump is used
Old 27-Oct-2012, 22:07   #3
I've always used an out of tank pump. 7 psi max otherwise the carb float shut off won't cope. But the internal is good enough, but can't be run externally as it hemorrhages.
Kev 3 bar Bump !!! the B is nowhere near the P.
Old 27-Oct-2012, 22:36   #4
Ran an external pump on mine with the help from Ghostie above on advice and sourcing it. Bike ran so much better for me.
Old 27-Oct-2012, 23:03   #5
But that was replacing the Monster Vac pump with an electric one Craig, so the improvement can be dependent on the condition of the vac pump, and the vac acting on it.
The SS already has a decent electric pump and providing the filter in the tank doesn't get blocked is easily up to the job, after all the same pump is used in keeping a 900SS carbs topped up and I bet they drink fuel at a greater rate
Old 28-Oct-2012, 00:08   #6
Ahhh yes. Did not take note he said SS. And yea you know that Vac on mine was buggered.
Old 28-Oct-2012, 22:42   #7
Thanks for your comments, think ill stick with the one inside the tank, will clean the filter out though, did a trackday at brands in June and had no problems, if it isn't broke, dont fix it.
Old 29-Oct-2012, 08:31   #8
You will need to replace the filter as they are not serviceable.
Old 29-Oct-2012, 12:28   #9
banger san's Avatar
I rode with the same SS set up (internal pump & filter) earlier this year never gave me any problems
Old 29-Dec-2012, 22:11   #10
firestorm firestorm is offline
how does the internal filter come out of a 600ss tank
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 00:20.
