Old 12-Apr-2005, 11:12   #1
Walenut Walenut is offline
Mood: Erratic
Single Seat Conversion?
I’m putting a single seat on my Bip 916 and using the parts from the twin seat, I think I will need to buy new:
Plate 827.2.004.1A which is the plate that the striker bolts onto, it looks flatter than the BIP one?
Spacers x 2 for the above bracket,
Bolts x 2 for the above spacers,
Anything else?
Old 12-Apr-2005, 11:55   #2
Mr_S Mr_S is offline
They're the bits I bought for mine.
Although I ended up buying a full set of everything in the end so it was an easier swap.
Old 12-Apr-2005, 12:01   #3
Mood: Erratic
Thanks, right let's see if they've got the bits in.
Old 12-Apr-2005, 15:08   #4
dave996 dave996 is offline
dave996's Avatar
Mood: Fed up...
How much did all that cost in the end?
Old 12-Apr-2005, 15:12   #5
About £40, though I did get the light unit off e-bay for peanuts.
Most expensive new bit was the lock plate with the spigot on it, which was around £10.00
I think it's about £30 plus the light.
Old 12-Apr-2005, 18:36   #6
dave996's Avatar
Mood: Fed up...
Cheers Mr_S
Old 13-Apr-2005, 00:17   #7
Mood: Erratic
They've just charged me £30 for the plate that the latch plate bolts onto, and £5 for the spacers. Mr S did you have to cut the spacers down? The bolts are 60p each though.
Old 13-Apr-2005, 00:44   #8
Didn't have to touch the spacers, just put them on.
£30's a bit rich for a flat piece of steel with some holes in (I got a bargain then!)
60p for a bolt! Get a pair from somewhere else!!!
Old 13-Apr-2005, 11:02   #9
Mood: Erratic
To late now but where did you get your bits from? Mind you I did need them instantly as I'm MOT'ing the bike on Friday morning.
Old 20-Apr-2005, 19:26   #10
F1F3R F1F3R is offline
hello walenut.
did you get the parts fitted yet ?
i just ordered and fitted the same parts . but my seat sits miles in the air.
to me it looks like its needing dropped by an inch at least.
if possible can you post or email a picture
thnx
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:07.
