Old 14-Apr-2005, 17:47   #1
Catch Tanks
I know this has been mentioned before but could someone give a definitive answer to what is needed, how big and what has to go in to them please?????
Will the stock breather/tank/airbox assembly serve as a suitable assembly for the engine breather system?
Would simply a self tapper in the bottom of the plastic tank under the seat suffice as a drain???
Also the fuel catch tank. Does it have to be flame proof, etc.
Do the catch tanks require that are are sealed? I guess so?
The Desmo Dues rules don't specifically mention them but I know they are required by the ACU rules which I don't have a copy off...........
cheers
neil
Old 14-Apr-2005, 19:00   #2
scuffy scuffy is offline
Mood: Ready for another V-twin
Cant help with the catch tanks dude but if you want an ACU handbook give me a shout.
Old 14-Apr-2005, 19:37   #3
chicken chicken is offline
chicken's Avatar
From the 2005 handbook (bad punctuation and all);
"Oil Catch tanks & breather systems. Where an oil breather is fitted the outlet must discharge into a catch tank located in an easily accessible position and which must be emptied before the start of the race. The minimum size of a catch tank shall be 250cc for gearbox breather pipes and 500cc for engine breather pipes."
This is not an altruistic gesture - it's my bike that he's got to fit it to!
Old 14-Apr-2005, 19:41   #4
chicken's Avatar
also just saw that "Any part of the streamlining which faces rearwards, must be finished with rounded edges of 3.5mm min. radius."
Since I will only have the SS top fairing this probably means the sharp pointy bits at the bottom will be expose. Nelly, would you mind breaking out the dremel?
Old 14-Apr-2005, 19:50   #5
Have to say all this catch tank stuff is making me scratch my head a bit too
