     I didnt realise the 750's had a wet clutch - we learn every day.
 Accord to my bible.....
 1991 750 models had the dry clutch (seven steel and seven fibre plates) but was of two possible types.
 For 1992 the wet clutch was adopted which affect bikes from engine number 001275. The hydraulically operated wet clutch has:
 8, 1.5mm steel driven plates
 8, fibre 2.5mm driving plates
 1 outside 3.5mm driving plate.
 Apparently all 1992 to 1997 (end of model run) 900ss's have the same clutch build:
 2mm steel plate splined to the clutch drum.
 7, 2mm steel driven plates.
 7, 3mm fibre driving plates.
 1 off, curved 1.5mm steel plate after the first driving plate.
 Hope this is of some use !!!
 Frank
