Old 18-Apr-2005, 21:41   #1
DC DC is offline
DC's Avatar
Mood: Double 9, Single 6.
Exhaust swap
Hello peeps,
I have the 45 mm carbon cans on my748/853 and I am wondering if there is going to be a benefit to fitting the 50mm link pipe and 50 mm end cans. I know that the 748R has this size system and a little info would be appreciated.
As my bike stands now, it has the FIM ultimap chip that is designed to run on the 853 modification to the engine. Am I going to end up with a hole in the midrange and lots of backfiring or is this exhaust change worth it?????
Cheers for the replies in advance.
DC.
Old 18-Apr-2005, 21:46   #2
keefer keefer is offline
keefer's Avatar
my sp runs a full 50mm system and it runs fine,
don't know what the benefit would be of just doing the link pipe and end can, as the down pipes would still be 45mm
if its not to much money I would go for the complete system,
but as to how much better that would be, I haven't got a Scooby doo
Old 18-Apr-2005, 23:29   #3
Mr_S Mr_S is offline
Should give you a few bhp more (in the top 2-3K) and a deeper note
45/50 system will keep the midrange that you have, full 50 system will cause holes in the midrange but gain more in the top end again.
I guess it depends what you want.
I kept 45 all through after the rebuild as I like the torque as it is, and didn't want holes in it.
Old 18-Apr-2005, 23:34   #4
keefer's Avatar
would be interested to see any dyno info you have on that compared to mine,
as it seams to have quite a smooth tork curve
Old 19-Apr-2005, 20:40   #5
DC DC is offline
DC's Avatar
mmmmmmmm,
Interesting. I am not really bothered to much about massive power gains, just wanted to know that the 45/50 mm system was not going to leave a massive hole in the midrange or something like that.
I suppose I am being a bling tart.
I am just trying to upgrade as I go, I was thinking that If I had the 45/50 mm system and then wanted to add a few more engine mods, it may pay off in the long run.
Anyhow,
Thanks for the replies.
DC.
Old 20-Apr-2005, 12:31   #6
There's some stuff on the Sigma site about this, and my info comes from the discussions I had with steve at MR about fitting a full 50mm system when mine went in for the SP conversion (I'm running Corse cam timing as well and had the offer of a very cheap Ti 50mm system).
I was advised against a full 50 system because I ride a lot on the road, so bottom / mid range is important and this would be affected with a full system, particularly bad below 5K. 45/50 for me only gained a marginal increase and wasn't worth the expense, so I bought mag wheels instead
45/50 was recommended for my setup , although DC since you're running an 853, you would probably be in a better position for running a full 50mm and will have no problems with a 45/50 system.
Old 21-Apr-2005, 18:52   #7
Rip Rip is offline
Mood: Mellow
If you haven't seen it before look at www.moto-one.com.au/performance/ . They show lots of useful stuff in their reports. If you want mid-range stick with your current set-up, top-end go large. Seems only 'R' cams are imune to the mid- range hole. Probably because these cause an even bigger one of their own.
Old 21-Apr-2005, 23:01   #8
Lee1980 Lee1980 is offline
Bikes: Xdaivel
Lee1980's Avatar
Mood: Xdiavel..awesome!!
If u want u can just put 50mm cans over the standard 45mm mid section
a bit tight but it fits, i have pics if u wann a see em.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:46.
