Old 23-Apr-2005, 21:58   #1
JohnDa JohnDa is offline
Fitting new seat
Managed to acquire a ducati comfort seat today, haven’t had chance to look at the bike yet but how do you go about changing it. Any advice / tips would be appreciated.
Old 23-Apr-2005, 22:02   #2
Well...
On each side of the seat unit you will see 2 bolts, one from each side bolted to the subframe, take those out, there are another 2 under the seat unit bolting it to the subframe also.
The tricky bit is that the tank is bolted to the seat unit (17mm nut), you can now either remove the entire tank, seat, seat unit as one, or just remove 17mm nut, you'll have to lift seat unit to get access underneath to get to this, once this is removed you can remove seat pad/seat unit as one, undo several more bolts to remove seat pad, and then pretty much reverse the process
HTH
Old 23-Apr-2005, 22:07   #3
Cheers JPM, will have ago at that tomorrow
Old 23-Apr-2005, 22:46   #4
If you get stuck give me a shout, not about tomorrow, but you're in Cheshire so could pop down in the week
Old 24-Apr-2005, 22:23   #5
Well.... any luck?
Old 24-Apr-2005, 22:25   #6
Not tried it yet JPM was to busy out playing today, going to give it ago in the week, thanks for the offer.
