Old 25-Apr-2005, 08:46   #1
Henners Henners is offline
Running-in Secrets
This puts an interesting slant on how best to run an engine in for full performance ....
http://www.mototuneusa.com/break_in_secrets.htm
Old 25-Apr-2005, 11:08   #2
Mr_S Mr_S is offline
You should read the section on high velocity intakes, narrowing the inlets down instead of opening them up!
http://mototuneusa.com/thanx.htm
Old 25-Apr-2005, 13:24   #3
If the air/fuel mix is moving too slowly the fuel can drop out of suspension and pool on the sides of the inlet. Leaving the surface rough helps by causing turbulance which encourages mixing. the last thing you want is a mirror smooth surface.
Old 25-Apr-2005, 13:28   #4
psychlist's Avatar
Mood: Lucky? For some, maybe!
running in secret Henry?
You doing next years London Marathon then?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:00.
