DesmoDue Parts For Sale & Wanted
This section is for all your DesmoDue race parts, accessories and the like.
Old 29-Nov-2012, 21:51   #1
Wanted Please
Not often I ask for anything. But I've had a fully stripped 583 engine in a box for a couple of years and decided it needs to go together.
Few bits missing, but what I need most is the alternator rotor
If anyone has one to sell please PM me.
Old 30-Nov-2012, 02:31   #2
I got your Text Phil but I don't think I have any in my spares, I think the similar ones I have are early 748 single phase ones which I think are a bit thicker
Old 30-Nov-2012, 13:16   #3
dunlop0_1's Avatar
Is it the magnety bit you want Phil? I have one, as Kev said they vary in size. This is 108.9mm ID (3 phase).
Old 30-Nov-2012, 16:00   #4
109mm ID surely OD
Its a 583 motor so a single phase jobbie 2 yellow wires. I'm up at Jan's this weekend so when I get back I'll measure inside of the windings and the depth that's available on the crankshaft end.
Old 30-Nov-2012, 17:40   #5
dunlop0_1's Avatar
Originally Posted by Ghost
109mm ID surely OD
Due to the current cold weather the coefficient of linier expansion affects the molecular structure of the caliper in such a way it manifests as a negative thus causing it to under read.
and I thought you where an engineer.
Old 30-Nov-2012, 18:28   #6
Maybe it was the expansion/contraction properties of the Rotor that were subject to change from the cold weather casuing it to shring from 109mm to 108.9mm
or if they were digital calipers the battery volts were possibly pulled down in the cold casuing the reference voltage to drift and an error to occur
but whats 0.1mm between friends
Old 30-Nov-2012, 18:32   #7
I reckon you are using a Chorley calibrated G cramp. I thought I was an engineer as well, but just found that I'm actually gay.
Old 30-Nov-2012, 18:33   #8
You know the old adage Kev, size matters.
Old 30-Nov-2012, 18:48   #9
yep I know i need bigger wotsits to run nearer the front, then again I hear dodgy eyesight helps as the gap may look bigger than it actually is even if its only 0.1 of a millimeter
Old 30-Nov-2012, 19:16   #10
dunlop0_1's Avatar
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 00:12.
