Old 30-Apr-2005, 20:25   #1
sparkin sparkin is offline
sparkin's Avatar
Problem with me water
Got back from a short blast to get some chain lube(25miles or so)stopped to do lottery,got back on the bike and the temp guage was on 90,got home and the was coolant on the rear hugger and exhuast Popped the seat off ,no sign of split header tank,but there`s a hole in the filler cap,looks like there should be a valve or type thingy in it but it`s not there now the only thing I can think of is I might have over filled it last week.Now the thing is I want to go to Cadwell in morning,I`ve never had fluid come out before even on the hottest days,so I`m thinking the over fill could have caused this,if so should I plug it or run with it open?I have removed some fluid and checked for air locks.
Old 30-Apr-2005, 20:29   #2
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
That'll be the vent to allow excess coolant out when it gets hot if the bike has been overfilled.
Mine looks just the same
I'd put it back.........check your level tomorrow morning before you start the bike just to be sure your level is correct.
Old 30-Apr-2005, 21:13   #3
sparkin's Avatar
When you say vent do you mean valve or just a hole?There`s a valve type affair in the middle but the outside hole is"just a hole"
Old 30-Apr-2005, 21:47   #4
sparkin's Avatar
Just been out in the garage,ran the old gal till the fan cut in,about 100degrees,with the bottle cap off.No pressure build up,all hoses and radiator hot,just probably overfilled it.The temperature dropped after the fan cut in,then fan cut out,ran it`s some more fan cut in again,switched off,fan still ran for a minute or two,all seems ok.
Fingers crossed
Old 30-Apr-2005, 23:47   #5
wheelspin
sounds like the bikes a binner mate.
Old 30-Apr-2005, 23:56   #6
sparkin's Avatar
Cheers mate:P
Old 01-May-2005, 04:32   #7
shmoki shmoki is offline
Your bike is as it should be, just excess coolant more then likely. I had the same on my bike first big ride after service. I was paranoid so I cleaned up the rear cylinder, which also had coolant splatter on it just to make sure gaskets weren't leaking.
But if you decide to bin it I am after some bits...
Old 01-May-2005, 09:21   #8
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Yep, tottaly agree, just slightly overful. Mine's done it too.
Ride on,
Rob
Old 01-May-2005, 11:13   #9
keefer keefer is offline
keefer's Avatar
a coolant system should not have any open vent in it,
otherwise it would not be able to run under pressure,
and would therefore boil
Old 01-May-2005, 21:59   #10
sparkin's Avatar
There`s a pressurised cap on the radiator of course,I think there should be a release valve in the header cap,but there isn`t onethere is still something not right,an airlock perhaps??Got home from DD,temp guage on about 80,switch off and the fan cuts in
How do you remove an airlock?Has anyone got a picture of there cap so I can compare?There is an allen bolt at the bottom of the rear cylinder which releases coolant when you undo it,but what`s the correct proceedure?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:41.
