Old 02-May-2005, 09:48   #1
Bikes: ST4S
Mad Dog Bianchi's Avatar
Grind Away!
Just took a ride to see the Japan Indy 300 at Honda's Twin Ring Motegi. They have built an oval there for Indy cars and Nascar. Pretty fast, pretty loud. Anyway, the STs4 was a pleasure to do the 360 km round trip, but I am a little bothered by the semi-grinding noise that comes from around the rear suspension when leaving a stoplight. Had the same kind of noise on my Gilera and never figured out where it came from. It occurs in concert with the front supsension rising and the rear subsiding. Any ideas??
Old 02-May-2005, 10:07   #2
Typical noise a ducati dry clutch makes when it needs cleaning out.
Old 02-May-2005, 10:52   #3
Bikes: ST4S
You mean after only 2300 km...My Gilera doesn't have a dry clutch, but makes the same noise. Maybe I should stop dropping the hammer at every stoplight....LOL
How did your move go Paul?
Old 02-May-2005, 21:33   #4
Hi again. The move went well, its the last time i do it myself though! Still loads to do including fitting a new bathroom suite and building a shower!
2300 km isnt a lot to be honest but i have found that if you are a bit keen with the clutch then it can make that noise quite easily. Mine is worse two up becasue i use more revs. If you are used to jap clutches that are mostly fit and forget then i guess its possible that you could have generated enough dust in that time to make it slip a little.
Old 02-May-2005, 22:04   #5
moozaad moozaad is offline
Bikes: Ducati ST2
Mood: Fruity
yeh, STs kinda get a glaze+dust combo coming. Use it as a prompt to learn better clutch control
I replaced mine with the 48 tooth setup. Soooo much quieter and no grinding yet.
Old 02-May-2005, 23:03   #6
I found a 14 tooth front sprocket helped quite a bit as well.
Old 02-May-2005, 23:37   #7
Glyn Glyn is offline
Glyn's Avatar
Mood: st2......we can rebuild
sounds like dust to me an all
when i first got mine i was cleaning it out every 3k or so
must be getting better aint had to do it for a while
Old 03-May-2005, 09:00   #8
Bikes: Ducati ST2
Mood: Fruity
also open clutch covers let the dust escape.... but let the weather in
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:05.
