DesmoDue Parts For Sale & Wanted
This section is for all your DesmoDue race parts, accessories and the like.
Old 10-Dec-2012, 21:29   #1
paynep's Avatar
Mood: Wet wet wet
Has anyone got...
....the little bracket that bolts to a carby SS frame behind the headstock so you can hold the tank down?
If you have a surplus one, please let me know how much you'd like for it.
Thanks, Paul
Old 10-Dec-2012, 21:36   #2
I made a couple of stainless ones and I gave the last one to Nog. I could make you one but would need hole centres.
Old 11-Dec-2012, 11:45   #3
paynep's Avatar
Mood: Wet wet wet
Cheers Phil, I will measure up when I can get back into the garage.
Old 11-Dec-2012, 14:31   #4
I doubt he'll be needing it now...
Old 12-Dec-2012, 06:49   #5
yendor yendor is offline
He might to hold the cheeks of his own a--e together.
Old 12-Dec-2012, 21:09   #6
paynep's Avatar
Mood: Wet wet wet
They are 42mm apart. The fixing holes on the frame, that is!
Although its freezing in the garage so the frame may have shrunk - I know after 10 minutes out there I had......brazing torch anyone?
Old 12-Dec-2012, 21:45   #7
Okies, I'll make you one up, should have it done over the weekend. Usually inspection dept's are kept at 20°C so your calibrated G cramp may be a tad orf.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:12.
